Old 20th September 2005, 02:28 PM   #1
aht is offline aht  Thailand
Account Disabled
Send a message via ICQ to aht Send a message via MSN to aht
Thumbs up Superb OPAMP preamp
My friend from Chicago send me of his idea for design super comprehensive preamp.
The concept is output = (original input sum with negative feedback) then sum of product go to sum with original input again.
This method he called Error Correction Output Revise or ECOR.
If anybody have some idea to improve this schematic please write your idea here
PS. He told me this schematic had edit from PS AUDIO ???
regard
AHT
Old 20th September 2005, 03:16 PM   #2
analog_sa's Avatar
Can't say i see much sense. A single driven instumentation amp with an extra feedback? The concept may be valid with power amps but all these opamps work under pretty much the same conditions. And the feedback is through a unity gain opamp? Why not use a direct connection? I probably don't understand it.
Old 21st September 2005, 12:43 AM   #3
Account Disabled
Smile OK...new schematic
I received this schematic from scanned but after I rewrited I forgot POT & OUTPUT....sorry sorry sorry :-)
Please suggest me again
regard
AHT
Old 21st September 2005, 01:21 AM   #4
sam9 is offline sam9  United States
sam9's Avatar
If you are just trying to minimize noise & distortion while placing a buffer after the pot it would be hard to improve on a single AD797 with external compensation for unity gain. If you are truly fanatic you could force it into class A and add a BUF634 inside the feedback loop. That should give you three zeros between the decimal point and the first sugnificant digit and supply all the current the next stage could reasonably want.
Any opamp at unity gain has gobs of NFB.
This is not to say the schemtic doesn't work, it's just hard to see why one would go to all that trouble.
Old 21st September 2005, 02:46 AM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Has anyone build it
Preamp opamp upgrade d3imlay Solid State 9 29th May 2011 11:53 AM
PS for opamp preamp Tolu Power Supplies 1 31st October 2008 09:53 PM
preamp with opamp...help cukkurullo Solid State 4 31st May 2006 07:25 PM
preamp opamp problems jnxw2 Solid State 7 27th May 2003 01:26 AM
OpAmp in preamp Kevin McCready Solid State 4 18th September 2002 07:30 AM
Page generated in 0.07825 seconds (72.92% PHP - 27.08% MySQL) with 11 queries
