Dear Sirs,
first of all I declare my ignorance in electronic circuits design. I just need a minimal schema for a single bjt buffer to be used in a unity gain preamp (or directions to where I cand find it). It should drive easily a 1000 ohm load (so some amount of current is required). I would like to use a 24V power supply. I have big problems in choosing the right resistance values. Thank you to anyone willing to help me. Kind regards. beppe61 |
#2 |
Hi
A NPN transistor can be arranged as follows: Use a NPN such as the BC547 which should be capable into a 1000 ohm load. The collector pin is biased at 1000 ohms for every volt of supply (so you will need about 24K - 22K or 27K will be fine ) running from your DC 24 positive volt source ( with the transistor writing facing you the collector is on the left) with a BC547 ) The output of the circuit is on the collector also and is usually arranged with a coupling capacitor you should make the voltage rating equal or higher than the DC voltage supply - its positive leg if using a bipolar cap is connected to the collector leg with the negative available as the circuit output. The base ( the middle pin ) has the input source attached also capacitively coupled. ( a 220n cap should do) From the base back to the collector arrange a resistor of at least 1Meg ohm up to 3M3 this self biases the base of the transistor. The emitter the pin on the right - and the only one available now - is usually just grounded. This forces the input signal at now a much higher level to be opposite in phase to appear on the collector. If you need some control over the level of this little circuit to assist in it being unity gain you could make the emitter the output - which is then the same phase as the input of course it would have to be ground lifted and this is where you could control the level with resistance making the capacitive coupling from the emitter leg and resistance - to start with say 470 ohm to ground. The emitter then drives the circuit rather than the collector and can be very effectively trimmed for output level. You will however reach a point where the audio frequency will reduce as it is just too close to ground. You could of course resistively tailor the output taken from the capacitor attached to the emitter or collector so that it approaches the unity gain you require. 3K3 in series with about 600 ohm to ground might be a starting point to try Hope this helps, this circuit is a good performer and hopefully will provide the result you desire. Cheers / Chris |
#3 |
Account Disabled
what does it have to be a bjt? it seems to me a small mosfet common source amplifier running fair hot is the ticket here.
#4 |
Electrons are yellow and more is better!
A BJT has higher gm (transconductance) which is positive when it comes to distortion.
/Per-Anders (my first name) or P-A as my friends call me |
#5 |
beppe61, you could also search for "diamond buffer" or "jung super buffer".
#6 |
Dear Sirs,
thank you very much indeed. I had in mind a circuit of the attached kind. But I know that in front of the base of the bjt I need a voltage divider and I don't know how to calculate the resistors values. Kind regards, beppe61 |
#7 | |
thank you very much indeed for your kind and very valuable reply. Nevertheless I would like to stay as simplest as possible. Just to see what is possible with a very basic circuit. With Vcc=24V I have to set : the Re value and the value of the two resistors to be placed before the bjt base to make the bjt itself working. I have read that the voltage differenze Vbase-Vemitter must be around 0,7 V. Am I wrong? But I don't know how to calculate Ve. After that I can calculate the right voltage divider to use in front of the bjt. I would like to use a BD139. Is it fine? Thank you very much again. Kind regards, beppe61 |
#8 |
Hi
There is no need for a divider if you use a self biasing arrangement ie 1M or up to 3M3 resistor from the base to the collector. Try it and see. Cheers / Chris |
#9 | |
thank you sincerely for your extremely kind and valuable help. I am afraid your indications are beyond my understanding capabilities. I would like to stress my ignorance on the topic. If I understand well, you advice to put a 1M resistor from Vcc to the base, of course coupling with caps the input and output. Is that correct? What value for the emitter resistor then? Thank you greatly for your extremely kind effort to teach me the basics. I must advise you that it will not be any task indeed. Eh, eh, eh. Kind regards, beppe61 |
#10 |
Dear beppe61
No - the 1M to 3M3 resistor is attached from the collector to the base. Not V+ to the base The collector is biased at 1000 ohms for every volt of supply ie it has 24K of resistance between the collector and the voltage DC source. You will find that approx .7v will be on the base once the 1M - 3M3 resistor is arranged from the collector to the base. Think of it this way -as a feedback path from the collector back to the base which it also achieves as well as self biasing. The BD 139 is a good transistor but is capable up to about 80Mhz ( i have used them as RF transistors ) though- it should be fine in this application. Take care with the pinout which is front view - left pin Emitter middle pin - collector and right pin base. Of course this isnt the only circuit for BJT buffering but it achieves a good result. Cheers / Chris |
| BEHRINGER SRC 2496 opinions kindly requested. | beppe61 | Digital Source | 81 | 5th March 2011 07:13 PM |
| Info kindly requested on the UcD 400 schematic. | beppe61 | Class D | 2 | 6th October 2006 07:26 PM |
| Behringer EP1500 - opinions kindly requested. | beppe61 | Solid State | 0 | 6th April 2006 09:40 AM |
| 6H30P based cathode-follower schema kindly requested | beppe61 | Tubes / Valves | 11 | 10th October 2005 02:35 PM |
| Single bjt (or fet) buffer schematic kindly requested. | beppe61 | Solid State | 0 | 14th March 2005 05:35 PM |
| Page generated in 0.11469 seconds (81.89% PHP - 18.11% MySQL) with 11 queries |
