#11 |
Thank you, Michael, i shouldnt post silly numbers,reverse transfer is indeed that low.
Still, works miracles for teaching me though. I do take it that separating Vas and driver stage by adding a driver stage between Vas and output stage will be a big improvement to distortion figures ? How about upgrading the trimpot to a Vbe multiplier, the value of the gate resistors and the feedback ? The advised heatsink was a 0.4 K/W model, 2 amp bias. |
#12 |
Thanks Jacco for the very informative explanation. I hope I can learn something and have the gut to experiment
At least, if the Hitachis get broken, I will not have to buy them again Spec above audible spectrum, is it really audible? Have you seen pavel Dudek's DPA330? He did almost everything in the circuit. If circuits like that 20W or the crescendo really need other stages, why are they not there? It's not difficult and not expensive to add 2 more stages correct? Will the problem discussed here be solved even partially, by adding such stages as found in DPP330? (Without the errorr correction, servo FB and other fancy components) |
#13 |
Electrons are yellow and more is better!
It wasn't DPA380?
http://sjostromaudio.com/dudek/dudek3/pics/dpa380.jpg http://sjostromaudio.com/dudek/dudek...s/DPA380_1.pdf http://sjostromaudio.com/dudek/dudek...s/DPA380_2.pdf
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#14 |
No, DPA330 uses Hitachis. DPA330 is the grand grandpa
#15 |
Oh, but they share the same topology. 3 transistors in front of the error correction circuit, that's what I was referring to.
#16 |
DPA330 schematic
The 2SD760/2SB720 Pavel uses as drivers for the mosfets are great devices:100 MHz, 2 amp max., also by Hitachi. You can still get them at Nikko elec., not cheap though, expect more than $1.50 the piece. (i am also still an aficinado of opamp dc-servo's, bipolar dc blocking capacitors are so outdated) |
#17 |
Looking at the topology of the Klasse A-versterker van 20 Watt amp, it looks very similar to the pass labs A75 but with transistors as opposed to mosfets.
#18 |
The cascoded Vas stage, yes.
But other than that i see more differences than resemblances. The A75 was the last amplifier i constructed in 1995, after finishing Mr Thagard's 100 watt 1990 mono design, after that 10 years nothing. The output devices i used for the A75 were 630/9630s because i couldnt lay my hands on TO3's.(see datasheet of the irf230) Performance of the 20 watter is in no way comparable with the A75. The A75 pdf's should be good reading, Jay. They should still be on the download section of PassDIY. I still need to scan the xerox copies of the Norman Thagard 100 watt design and mail it to a diyaudio member. Anyone else interested in having it can send me a word. |
#19 |
you can send me a copy lbhajdu[at]optionline[dot]net.
#20 |
Yes, jacco I'm interested in the Thagard. Please send me also, thank you.
Jacco, I haven't yet checked the pdf but I built A40 once. if I'm not mistaken they differ 'only' on the number of output transistors. And as I can remember they are BIPOLAR! I'm not looking for high class amp here (I have built enough free designs ), I'm just looking for a high class amp for my expensive K135/J50 But you seem to like the A75. Hmmm... I think NP himself don't like bipolar??
| versterker 70fa951 | char | Solid State | 1 | 1st February 2010 03:56 PM |
| Zen 10 watt amp | broadcast guy | Swap Meet | 1 | 18th June 2004 02:42 AM |
| 100 watt amp | sepo | Chip Amps | 3 | 5th February 2004 05:10 PM |
| SOZ < 1 watt possible ? | Chul | Pass Labs | 5 | 27th May 2003 01:33 AM |
