Old 27th September 2005, 07:57 AM   #11
just another
wintermute's Avatar
Hi Percy,
One thing that I found was causing very poor crosstalk results for me was "ground leakage" I put that in quotes because that is the best way I can think of describing it..... basically I had to put some low value resistors in the ground lines of my test probes, once I did this the crosstalk figures improved dramatically (from around 40db to around 80db). What tipped me off in the end was that the crosstalk was good when I used a cd (with the rmaa test tones on it) and bad when I used the pc soundcard for both output and input I wanted to use the pc for output as I could use 96Khz which I can't with my DVD player. from memory I used 6.8 ohm resistors.
what I think was happening was that the speaker return was partially going back to the amp and partially going through the sound card and out to earth...
here is a link to the tests I did on my Audigy II ZS if interested --> http://home.people.net.au/~tonywww/r...ZS%2096Khz.htm
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 27th September 2005, 10:05 AM   #12
MikeB is offline MikeB  Germany
MikeB's Avatar
Hi percy !
I am sorry to be rude, but your soundcard is not really "decent"...
I suggest that if you want to do more measurements to get a more
sophisticated soundcard !
I attached the crosstalk from the soundcard i am using now, it is
a "m-audio delta 2496", not too expensive and not built for gamers...
Have you verified that your loopback-cable is not defect/unshielded ?
Full report:
http://www.lf-pro.net/mbittner/rmaa/M-Audio_32b96.htm
Mike
Old 27th September 2005, 12:08 PM   #13
percy is offline percy  United States
Originally posted by amplifierguru
Your crosstalk is not good - what is the composition? My last commercial amplifier had 91dB channel seperation - at 20KHz, using a common power supply. At 91dB + the composition doesn't really matter.
Greg
Is that under load or no load condition ? and at what power ?
I was operating at about 3W rms into a 5-ohm resistor. Maybe my amplifier vocabulary is bad but not sure what you mean by composition. Its a Technics Stereo Receiver - basically a chip amp with Class H+ configuration.
This is a pic of the no-load xtalk. Its better than the one under load.
This brings up another question - is it normal for xtalk to increase under load ? And this is a very light load as compared to what it can take (100W into 8ohm, I know it is 4ohm stable).
edit:- Note that it is following the trajectory of the soundcard's xtalk.
Old 27th September 2005, 12:29 PM   #14
SY's Avatar
Originally posted by percy
Its a Turtle Beach Santa Cruz.
This is a good place for a few sound card comparisons and test measurements - http://www.pcavtech.com/soundcards/compare/index.htm
It doesn't look like the measurements include many currently-available cards. If anyone knows a more up-to-date series of tests, I'm highly interested.
If there's a sucker born every minute, where do the rest of them come from?
Old 27th September 2005, 03:08 PM   #15
and what better place than this(diyaudio.com)!
If you think it makes sense then you could start a thread(sticky ?) in the Digital forum and let people throw their test results in it for the newer cards. I am sure there are many people over there with the type of cards you are looking for and also have test
results already available.
Old 28th September 2005, 07:31 PM   #16
MikeB's Avatar
Hmmm,
After i realized that i have to upgrade my win2k to sp4 to have real 24bit,
i updated the measurement for my soundcard...
I think for 90Euro a good choice for doing measurements !
See yourself:
http://www.lf-pro.net/mbittner/rmaa/...elta_24_96.htm
Mike
Old 28th September 2005, 10:55 PM   #17
just another
wintermute's Avatar
not a bad idea, but would have to have some rules ie standardised version of RMAA and standardised settings for the test, otherwise everyone could use different versions/settings and it would be impossible to make real comparisons the things you couldn't standardise are things like the cable used, OS, other pc hardware etc, so even with the above there could be other variables that make comparison difficult.
Tony.
Some of my photos
Old 29th September 2005, 01:44 AM   #18
sam9 is offline sam9  United States
sam9's Avatar
There are a few even more fundamental things to work out. I've made a few loop-back tests with RightMark and the issues regarding choice of wires and versions are a ways down the page on my list of issues. Among the things to be considered is how to get comparable and reproducable results when the mixer software is different for each card and when the ability to set the mixer sliders exactly the same way twice with your mouse is dubious. Very small changes in mixer position seem to make really big differences.
One thing I have not done yet but I suspect is important is to use a buffer in the loop-back. I say this because my impression is that some cards (I include Santa Cruz in this) don't seem to have matched the impedances of the output and input jacks well. Why should they? They werre not designed for that. As an exaple the Santa Cruz (again) seems to benefit from something a simple as a few k-ohms of resistance added to the loop back. This suggests to me that the card's output can barely derive it's input. Again, why should it?
After some of these proceedures are worked out, then that's the time for fine tuning.
2 channels to 1 crosstalk dreamtear Parts 1 19th January 2008 01:42 AM
Crosstalk in twintriodes? Ryssen Tubes / Valves 7 22nd June 2006 05:55 AM
Crosstalk cancellation Prune Digital Source 10 19th January 2006 02:19 PM
PSRR and Crosstalk dgardner Solid State 4 20th June 2005 01:09 PM
A question on crosstalk sardonx Solid State 6 21st June 2004 11:45 PM
Copyright ©1999-2013 diyAudio
