Disaster NEED HELP PLS!
Old 18th September 2005, 06:25 PM   #1
leander is offline leander  Malta
Unhappy Disaster NEED HELP PLS!
Disaster
Hi people, I am in urgent need of help before going mad!
This is the amp Iíve just made and it took me a whole week to do it and managed to make it working perfectly.
( http://www.ampslab.com/c300.htm )
I wasnít so lucky the second time I hooked it up because as pumping up some music, the center tap wire (ground of amp) went loose and the thing just freaked out!
I switched of immediately and rehooked the ground properly, however only a loud buzzing sound was heard! A disaster!
Checked out the components, no components were carbonized.
Checked out two power transistors any hfe resulted to be fine (aprox150)
As a start Iím thinking of replacing all small power bjt transistors.
Iím not an expert in troubleshooting, PLS what is your opinion about the problem
Here below is a schematic of the amp with grounds illustrated with red boxes
Old 18th September 2005, 07:19 PM   #2
Jan Dupont is offline Jan Dupont  Denmark
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Check the Vbe (Voltage between base and emitter) on all transistors like this:
Connect the input to gnd.
Do not connect any load.
Watch out for components that get hot.
Power up the amp, and meassure the Vbe's.
They should ALL meassure app. 0.6 Volt +/-50mV
Good luck
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 18th September 2005, 07:47 PM   #3
dtrif is offline dtrif  Greece
Default Keep in mind that a transistor that measures a normal hfe,
may be damaged (it has happened to me). Your desicion to replace small transistors is quite reasonable, as they are more commonly damaged in such situations. In a situation like this, where I couldn't find a solution, I simulated the whole thing, found voltages in different places in the simulator, and compared them with real life. Wrong voltages existed around a small signal transistor (previously measured with a normal hfe). When I replaced it everything was ok.
I am not a repairer professionally, so this approach may be wrong. It's just what I did. Anyone else with more experience please contribute. It may be even a passive component (capacitor perhaps), which would be very unfortunate, because I thing it will be much more difficult to find it.
Dimitris
Old 18th September 2005, 08:26 PM   #4
jaycee is offline jaycee  United Kingdom
Check Q5, Q6, Q8. Also check your filter capacitors arent damaged.
Old 18th September 2005, 09:48 PM   #5
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Did you check that your supply voltages are normal? Fuses?
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 18th September 2005, 10:55 PM   #6
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Hi leander,
just of curiosity to your amplifier, I may be a bit tired to think clearly as it's 2 a clock in the night here, but what is the idea behind the VAS formation around Q 9 and Q 10?
Cheers Michael
Old 18th September 2005, 11:05 PM   #7
Tim__x is offline Tim__x  Canada
At first glance, Q9 appears to speed up turn-off of Q10. Though perhaps there is more to it than that.
Old 18th September 2005, 11:26 PM   #8
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
With mirrored LTP and EF buffer at clipping Q10 needs such limiting. Otherwise would saturate very deeply and potential on its base would be close to zener voltage of D1. I'm not sure if I'm right but it definitely looks to do nothing in 'linear' range.
Old 18th September 2005, 11:40 PM   #9
Q8 and Q10 form an EF VAS. Q9 is a safety cutoff, when the VI limiter activates it can result in Q10 being saturated. Q9 detects this and cuts the base current.
Leach explains this for his own amplifer here
Old 19th September 2005, 06:23 AM   #10
powerbecker is offline powerbecker  Germany
Yes and no :collector of Q9 must go to base of Q8, R18 should be zero!
Disaster NEED HELP PLS!Hide this!Advertise here!
[DIY] HEXFET AMP total disaster? egberttheone Solid State 74 29th January 2017 07:10 PM
Ebay Tube amp buy disaster itsmejto Tubes / Valves 55 20th June 2008 08:34 AM
Zanden tda1541a NOS review disaster! ash_dac Digital Source 0 21st February 2007 03:37 PM
Near Disaster! Bikeman Everything Else 1 4th September 2003 05:18 AM
Copyright ©1999-2017 diyAudio
