Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 18th September 2005, 11:10 AM   #1
Default cross-quad and cascomp circuits
I've read several threads about Professor Hawksford, and I know that he has the cross-quad and cascomp circuits for input stages in a couple of his papers.
Could someone tell me exactly what the advantages are of these circuits (that is, why someone would want to use them)?
Thank you!
Old 18th September 2005, 10:09 PM   #2
jcx is offline jcx
http://db.audioasylum.com/cgi/m.mpl?...rophead&n=3169
http://www.analog.com/UploadedFiles/...917MAT04_d.pdf
(fig 6)
Hawksford also explored some related diff pair input linearization techniques
J4 DISTORTION CORRECTION CIRCUITS FOR AUDIO AMPLIFIERS, M.O.J. Hawksford, JAES, vol.29, no.7, 8, July/August 1981
At http://www.essex.ac.uk/ese/research/...lications.html
Somewhere you might also find Gilbert’s “multi-tanh” proposal
Its not clear that these techniques are necessary in audio amplifier design - high loop gain, emitter degen and bootstrapped cascode appear to be enough for super low distortion in audio amp inputs
Old 18th September 2005, 11:39 PM   #3
Steven is offline Steven
Steven's Avatar
http://iroi.seu.edu.cn/jssc9899/33ss...01-gilbert.pdf
Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973
Old 19th September 2005, 12:54 AM   #4
dimitri is offline dimitri
dimitri's Avatar
Send a message via ICQ to dimitri
Quinn's US pat 4897611
it is either 4,146,844 or 4,692,712
4897611 is very high gain positive fb cmos amp
Old 19th September 2005, 04:34 PM   #5
jcx is offline jcx
thanx dimitri
4146844 fig 4 looks like what I was thinking of, don't know were my ref came from
I believe the cascomp was actually used in tektronix front end amplifiers - unusual for a patented circuit
The main utility of these enhancements would be in situations where you cannot have high global loop gain
in audio amplifiers it is quite possible to keep the differential input V << 1mV with high loop gain - then the ordinary diff pair is linear enough to not be the limmiting factor
Old 21st September 2005, 02:29 PM   #6
dimitri's Avatar
Default Gilbert curcuit
I1/2=I2=I3=1ma, I4=20mA
Quinn added series cascode after this
Old 21st September 2005, 02:34 PM   #7
dimitri's Avatar
transfer characteristic and differential gain, it is interesting that the diff stage (Q2, Q3) and current amp (Q4-Q7) nonlinearities are compensated
Old 21st September 2005, 02:41 PM   #8
dimitri's Avatar
see also: B.Gilbert, A new wide band amplifier technique, IEEE J. SSC, 1998, pp.353-365
Old 22nd September 2005, 02:22 AM   #9
mikeks is offline mikeks
Account Disabled
Default Re: cross-quad and cascomp circuits
Originally posted by rtarbell
...Could someone tell me exactly what the advantages (of cross-quad and cascomp circuits for input stages)....
Virtually no value to the designer of discrete amps...
Old 22nd September 2005, 08:40 PM   #10
Tom2 is offline Tom2
Dimitri, 1968 instead of 1998.
IEEE J. SSC, 1968, pp.353-365
rtarbell,
Also the book "Analog Circuit Design", edited by Jim Williams and published by EDN, has two chapters by John Addis and Barrie Gilbert that might help answer your question.
Tom
Thread Tools
Connecting Virtual Ground Circuits with True Ground circuits?? Minion Solid State 1 12th February 2007 02:28 AM
Research on tubes and circuits simple circuits Cazcotty Tubes / Valves 6 16th June 2006 01:50 PM
The Cross Quad diff Ultima Thule Solid State 48 12th February 2006 08:12 PM
85 powersupply circuits 58 charge circuits gev Power Supplies 0 31st July 2005 12:27 PM
How to cross over Learnincurve Subwoofers 7 30th January 2005 07:42 PM
Page generated in 0.19188809 seconds (82.79% PHP - 17.21% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
