#11 |
Thanks for all of your inputs! Let me ask, supose I were to make the cascomp in my input stage. I would make the regular differential pair with about 5mA of tail current and an active load to the VAS stage. For the inner differential pair (the cascomp circuit itself), is there any rule of thumb as to what its tail current should be?
#12 | |
Does Distortion decrease by local feedback or global feedback? Does this techique have any improvement in a whole amp ? or Is it good when do analysing the only input stage ? Thanks !
Justice for Victims of Agent Orange http://www.petitiononline.com/AOVN/Thank all of you! |
#13 |
Hi
What is the main difference between multi tanh stage and so-called 'schmook pair' ?? the basic idea seems similar to me... has Gilbert re-invented what Schmook had before
#14 |
They seem to be the same, at least for the case 1:n and n:1 cross-connected.
See patent 5933054: http://www.freepatentsonline.com/5933054.pdf From this patent: " An example of the conventional bipolar OTAs was disclosed by Schmook in the IEEE Journal of Solid-State Circuits, Vol. SC-10, No. 6, PP. 407-411, December 1975, in which two unbalanced differential pairs of bipolar transistors are employed. Two transistors of each pair has different emitter areas or sizes. Output ends or collectors of the two transistors of each pair are cross-coupled. The transconductance linearization technique proposed by Schmook is known as the "Multi-tanh" technique, and has been practically used. An application of this Multi-tanh technique was disclosed y Tanimoto et al., in IEEE Journal of Solid-State Circuits, Vol. 26, No. 7, PP. 937-945, July 1991." This patent mentions an alternative approach to linearization.
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973 |
#15 |
At least Gilbert mentions Schmook in his paper, (Reference 4).
See #3.
#16 |
So Schmook's pair is multi tanh.
That's funny, I used to think it's Gilbert's invention. However Gilbert's article is great in terms of analysis and popularisation. |
| Connecting Virtual Ground Circuits with True Ground circuits?? | Minion | Solid State | 1 | 12th February 2007 02:28 AM |
| Research on tubes and circuits simple circuits | Cazcotty | Tubes / Valves | 6 | 16th June 2006 01:50 PM |
| The Cross Quad diff | Ultima Thule | Solid State | 48 | 12th February 2006 08:12 PM |
| 85 powersupply circuits 58 charge circuits | gev | Power Supplies | 0 | 31st July 2005 12:27 PM |
| How to cross over | Learnincurve | Subwoofers | 7 | 30th January 2005 07:42 PM |
| Page generated in 0.09731 seconds (74.69% PHP - 25.31% MySQL) with 11 queries |
