Old 18th September 2005, 07:09 AM   #1
Send a message via MSN to Retsim_X
Default output hum
hey people i have just finished a 200wrms x 2 solidstate amp
we have alternate power at home and run off a modified sine wave inverter.
the problem is i need a way to (when the volume is right down) to eliminate the horrible hum
like i mean you cant even use headphones the hum iss so bad and loud
plz i need help
ps the hum is comming from the speakers @ 50 hz
Old 18th September 2005, 10:10 AM   #2
actualy is it easiest just to rewind the trnsformer agian so it has +/- 80 v in the caps and regulate it at +/- 60 v ?
sry we run a modified SQUARE wave inverter
Old 18th September 2005, 10:53 AM   #3
How have you grounded it? Stargrounded? Is the inputs shielded?
Regulated PSU isn't a very good alternative
Old 18th September 2005, 11:55 AM   #4
absolutly it was one of the first things i did and checked
Old 18th September 2005, 03:49 PM   #5
If you have grounded everything in a perfect way like a star then the hum might go right into the main pcb. Take it and put it far away from the transformer and see if it helps.
I assume you have rectified the AC and youre using significant big reservoir capacitors
Old 19th September 2005, 06:22 AM   #6
+/- 50v power
8000uF caps
200wrms x2 amp
the amp board is on the opposite end of the 17" box
thank u
Old 19th September 2005, 08:08 PM   #7
Except some very particular designs...
Normally heavy hum is not caused by the ripple on the DC rail.
Ripple on the DC rail usually causes just some hum, but not heavy hum. And typically this hum would be 100Hz, not 50Hz.
Do you have the hum also, if the amp is not connected to any
signal source? No computer, no TV, no radio etc....
Most often you get such heavy hum, when you connect two parts of equipment that both are grounded. ... grounded at different points and causing a ground loop between two (or more) parts of the equipment. So most suspect are computers (PSU always grounded), TV (antenna grounded), radio (antenna).
Good luck
Markus
Old 19th September 2005, 08:47 PM   #8
Sometimes you will need to seperate the Audio and PSU grounds to elliminate ground loops within your amplifier system.
Does the amplifier hum get worse when you connect a source to it's input terminals?
For a start seperate the input audio grounds and see if it goes away(attenuates is probably a better word)
Comman practice is to lift this ground away with a 47 ohm (or thereabouts) resistor.
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
Page generated in 0.08785 seconds (75.04% PHP - 24.96% MySQL) with 10 queries
