Hello everyone,
I have been given a DIY project of a pre and power Amp from around 1972 which 'never worked'. I got this without schematics but that is no huge problem as I have almost reversed engineered it. Basically it appears that it uses 108 transistors paired with 503 and the final stage uses 3055 and 2955 transistors. I am not sure what the transistors marked 503 are (i believe they are PNP) can anyone clarify this? I also have at least one which is open circuit anyway so does anyone know is there a modern equivalent? thanks Daz |
#2 |
Because you talk about 3055 and 2955, may I assume that the 503 has some letters too, e.g. 2SC503 or 2SK503.
Also does the amp count 108 transistors or are you again referring to the label? /Hugo |
#3 |
Actually I might look for 2N503. since the 3055/2955 pair looks like 2N numbers.
2N3055 was a VERY popular NPN power transistor some years back, and the 2955 was its PNP complement. What package is this 503? TO220? |
#4 |
I think that '108' stands for BC108, I've seen these small signal transistors in old audio equipment quite often.
http://www.ortodoxism.ro/datasheets/siemens/BC109B.pdf '503' may stand for 2N503 but I have never seen these. http://www.datasheetarchive.com/semi...ecsheet=119447 |
#5 |
thanks for the replies guys,
the 3055 and 2955 have MJE marked on them,, I have found datasheets on MJE3055 and 2955 (NPN and PNP transistors) they are similar to TO220 package type, although they appear slightly bigger and there is a slug where the heatsink tab is (I am not sure when jedec packges where defined). I have made the assumption that the 108 are BC108. anyway the 108 and 503 are similar to the TO92 package type (just a bit squarer looking down) cheers Daz |
#6 |
KD503 used to be popular I think, but I'm not sure if you have them.
| Can bias transistor mount on top(body) of output transistor?? | Leolabs | Solid State | 23 | 16th February 2008 12:35 AM |
| what is this transistor (or fet) ? | ASSaBeong | Parts | 7 | 26th April 2007 02:01 PM |
| Transistor Id | glen65 | Solid State | 13 | 4th March 2006 10:31 PM |
| Best Transistor? | samsagaz | Solid State | 13 | 18th October 2004 09:22 AM |
| Transistor ID | EchoWars | Solid State | 6 | 24th January 2004 12:45 PM |
| Page generated in 0.08455 seconds (74.45% PHP - 25.55% MySQL) with 10 queries |
