I have made no simulation or test yet but I would like to have opinion on this circuit configuration
#2 |
here is the picture
#3 |
Me again.
Sorry inverting & non inverting input of op-amp are reversed |
#4 |
I did no test or make simulation but I found found that the integrator with no close loop will always fire after a period of time. So I am going back to the drawing table.
#5 |
Have you tried connecting a 1 meg resistor in parallel with C3?
It works at higher frequencies. As long as the other resistors are relatively low in value (less than ~50K ohms), it may work for your circuit.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#6 |
I guess this is a crow-bar circuit to blow the fuses should DC appear.
The detector seems overcomplicated to me. You could achieve the same effect with 4 diodes, an R/C filter and a few transistors to fire the crowbar. This would have the advantage that you can run it from the poweramp rails without needing any +-15v supply for the opamps. |
#7 |
A resistor across C3 is a great idea, I did not see this one by myself but after a quick analysis it is clear that he resistor will limt the gain at low frequency and will solve the run away problem. tanks Perry
+15V an -15V could be a problem for most but my amp is build with old transformer from few IBM PROPRINTER stuff and there is 2 10 volts AC tap in the powersupply with 2 diodes and 2 caps I will have a non regulated supply for the OP amp. Thanks Jaycee for the hint |
#8 |
I made a few simulation and the new circuit is below
triac optocoupler led & stuff tig at 3.5 volts Response of filter including op-amp stage dc + 14 db 3Hz + 10db 1.6 Hz 0 db 4Hz -10db 8.5Hz -20db 16Hz -30db 30Hz -40db system should trig at 0.7 Volt DC |
#9 |
This type of circuit has to perform in two quite opposite directions. First, it should detect only DC voltage - thus removing everything AC at it's input. Secondly, it should react as fast as possible since you don't want to turn your speakers into heaters and melt them down in a matter of miliseconds. Improving one, degrades the other one. Of course, you want to react on rather low DC levels - 0.6 - 0.7 V (matches with the need for speed).
Attached circuit has performed quite well in all sorts of situations. Don't mind +33 V reference there. You can use different voltages as well. My suggestion is to use +12 V and to tie up CMOS 40106 or CMOS 4093 (Schmitt-triggers) at it's output. Works like a charm every time Best regards, Nick |
| Leach amp VAS protection | Dem | Solid State | 17 | 1st April 2012 05:01 AM |
| My Leach Amp Clone (LEACH 150) | panson_hk | Solid State | 28 | 15th August 2011 08:12 PM |
| High Current Leach/leach super amp | bowdown | Solid State | 41 | 2nd March 2011 02:15 PM |
| speaker protection (OR) overload protection | myanmar | Solid State | 7 | 13th July 2006 08:21 AM |
| Leach Amp protection quistion | lykkedk | Solid State | 3 | 3rd January 2004 04:26 AM |
