Parasound HAC2200II, schematic needed
Old 14th September 2005, 09:39 PM   #1
mjctech is offline mjctech  United States
Default Parasound HAC2200II, schematic needed
I have a HAC 2200II One side is running hot still works. Need help
Old 5th September 2006, 06:42 AM   #2
pwgtang is offline pwgtang  Armenia
How hot?If you can touch the heat sink for a while means it is OK.
You can check the voltage on one of the 0.22ohm. If meter read
about 10mv to 14mv, I asscume average 13mv means total 350
to 360ma idle current.If the voltage too high you can adjust the
pot locate at middle the power pcb.Make sure you turn a little bit,
then check the voltage.The idle current decide the output watt
in class A mode.You do not want to set it too low.
Parasound HAC2200II, schematic neededHide this!Advertise here!
Parasound HCA-1200 schematic ? promitheus Solid State 13 16th July 2010 01:19 AM
Parasound HCA1500A amp schematic GATOR3000 Solid State 2 20th November 2008 02:52 PM
Looking for Parasound dac 1500 schematic elviukai Digital Source 5 14th October 2008 01:56 PM
Parasound AVC2500U schematic or help needed! excetara2 Digital Source 0 22nd June 2006 12:23 AM
Parasound Psp 1500 schematic Htguy Analogue Source 0 19th March 2005 02:07 PM
Copyright ©1999-2017 diyAudio
