Overload protection circuit. Does it work correctly?
Old 15th September 2005, 06:48 PM   #11
Fritzell is offline Fritzell  Sweden
Hey all thanks for so many replies.
janneman: I've omitted the dc-blocking cap on the feedback and put a DC signal on the input to get the DC signal on the output. This is because then i can test positive and negative voltage overload protection separate and see how it behaves.
I agree this circuit is somewhat incomplete and doesn't really work properly
The problem seems to be that on positive signal, the current is limited by the current-source and there's to much resistance to take any current from the VAS, but on negative swing the output protection has direct contact with the VAS collector and can sink so much current as the LTP input pair can deliver out * hFE of vas = too much Right now i don't see how to work this out
Old 15th September 2005, 07:20 PM   #12
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Fritz:
Add another emitter resistor and current limiting transistor to the VAS, like the ones you are using for the output devices. Clipping behaviour will also get improved.
Old 15th September 2005, 07:47 PM   #13
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Fritzell,
Strange, you would think that whatever is above the Vas, the current limit xsistor should be able to short the drive to the driver. I think the 12k is too large to sustain the base current for full shorting. Keeping the same current limit, try to change the divider from 1k - 12k to say 100 ohm - 1.2k. That should do it.
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 16th September 2005, 01:38 PM   #14
Hey thanks for all ideas. Here's the current circuit im been working with. I put a 22 ohm emitter resistor for vas and a transistor on vas base. When current exceeds something like 30mA voltage increases so it opens the transistor and leads away all base-current to the vas and this is how it works. In simulation this config seem to work very well.
I dont know how it will work in real life though. Will it cause oscillation or some other bad effect? Please comment this circuit
Im thinking of maybe adding an inductor on the output also..
Scheme:
http://upl.silentwhisper.net/uplfold...pschematic.GIF
Thanks!
Old 16th September 2005, 01:52 PM   #15
Eva's Avatar
I have never seen such a VAS current limiting arrangement oscillating in practice, but the classic output device current limiting arrangement may oscillate because it is closing a feedback loop across two more transistors. You should build a prototype and test it carefully.
Old 17th September 2005, 09:29 PM   #16
Okay i will try. Thanks all for your answers!
Old 19th September 2005, 02:19 PM   #17
jan.didden's Avatar
Scheme:
Thanks!
I see you changed one of the resistors across Re for current limiting, now the limit is MUCH lower. You sure you want to do that?
Jan Didden
Overload protection circuit. Does it work correctly?Hide this!Advertise here!
Overload and Short Circuit Protection space2000 Solid State 17 5th March 2009 10:26 PM
Amplifiers that not work protection circuit Hi Speed Car Audio 12 19th August 2007 04:23 AM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
Subwoofer overload protection? Axeman Subwoofers 24 5th September 2003 04:44 PM
