Old 11th September 2005, 12:39 AM   #1
Flavio88's Avatar
Question subwoofer amplifier schematics?????
Somebody have some schematics of a simple,high power(180w\4ohm or more) and reliable power amplifier for subwoofer use???
If possible, it does work with +37 0 -37volt power supply.
Old 11th September 2005, 01:27 AM   #2
jaycee is offline jaycee  United Kingdom
http://www.ampslab.com/c200.htm
You won't get 180W into 4 ohms with +-37V supplies though.
Old 11th September 2005, 09:07 AM   #3
you could build two 50w to 60w into 8r amps using +-37Vdc.
If you bridge them you MAY be able to get 180w into 8r.
The problem to overcome to achieve this is current delivery from both amps.
Let me explain. A 50w/8r amp should be able to give 90w/4r if built with a good PSU and a very good output stage.
A bridged pair will then achieve double power into double the load impedance. Thus you get 180w/8r.
However a good rule of thumb for designing an amp and it's PSU is to ensure it can safely deliver full load into a load impedance about half the speaker load. For a conventional amp this equates to safe power into 4r, no problem usually. But for a bridged amp each output stage thinks it is driving a load that is half the value actually connected across the outputs. This requires both amps to be safe pushing 180w into 2r (non reactive). At peak voltage (28Vpk) it is delivering 14Apk and the PSU must hold up while allowing BOTH amps to use 14Apk each.
Simpler and cheaper to use +-50Vdc to meet your requirement.
regards Andrew T.
Old 11th September 2005, 02:18 PM   #4
eugenio is offline eugenio  Italy
try this class d 2 chips solution by national
http://cache.national.com/ds/LM/LM4651.pdf
or Elliott Sound Products sw amps
http://sound.westhost.com/project68.htm
or also thi s for bridging
http://sound.westhost.com/project3a.htm
good luck..
ciao e buon lavoro.
Eugenio
I love music
Amplifier schematics macsaif Solid State 21 21st May 2012 09:15 PM
8" Subwoofer cabinet schematics needed. hernanstafe Subwoofers 12 6th February 2007 03:09 AM
amplifier schematics skogs Solid State 1 23rd October 2006 07:33 PM
Mystery Coponent in Subwoofer Schematics abid_rehan Chip Amps 21 14th August 2006 04:19 PM
am-u01 amplifier schematics pgbhat Chip Amps 0 3rd June 2003 11:21 AM
Page generated in 0.41640 seconds (21.11% PHP - 78.89% MySQL) with 10 queries
