Old 10th September 2005, 06:34 AM   #1
Send a message via AIM to silentblackhat
Default capacitor leads trouble
I have the radioshack 100µF 35V 20% Axial-Lead Electrolytic Capacitor for a preamp im makig. i cant tell which side is the posative and negative. it has aarows pointin towards a side(each lead somes out of the sides, the circle part of the side) but idk if its negative 100% or not. it looks like inside the aarow it might be a negative sign but it might just be a block inside hte aarow. any help would be appreciated
Old 10th September 2005, 06:38 AM   #2
Killjoy99's Avatar
I assume you are talking about the type of capacitor below:
In this case I beleive that the arrow is pointing in the direction of the negative lead, but don't take my word 100% on it. Maybe some others will know for sure.
Old 10th September 2005, 06:46 AM   #3
yes tahts the one but the aarows look different on mune, they are solid and mashed together. i saw that picture on radioshack.com.
Old 10th September 2005, 06:50 AM   #4
Killjoy99's Avatar
Ok, here you go. The site below says that with axials the arrow always points in the direction of negative terminal.
Electronics:Component Identification
You should be all set now.
Old 10th September 2005, 07:01 AM   #5
thanks alot, now i just need to go get a 820ohm resistor tomorrow and ill be set with this preamp circuit im building
Steel Leads and Tinned Copper Leads impsick Parts 0 19th April 2009 10:01 AM
capacitor brands & power transistor trouble on hk amp mrlennon Parts 15 24th October 2005 03:37 PM
Problem: Identify Positive and Negatve Capacitor Leads EchoWars Parts 8 30th May 2005 10:50 PM
Toroid leads? 4 or 6 Al.M Solid State 5 26th November 2001 11:41 PM
Zen Leads vdi_nenna Pass Labs 3 14th October 2001 12:46 PM
Page generated in 0.07748 seconds (77.05% PHP - 22.95% MySQL) with 10 queries
