Old 7th September 2005, 04:11 PM   #1
m0nty is offline m0nty  Italy
Send a message via MSN to m0nty
Default quick question ... really
i have just finished building a psu for my headphone amp
it's transformer + rectifier bridge + regulator + caps
now, the - (minus) from the rectifier bridge is ground.
my question is: should I connect it to the mains earth or not? i'm asking this because i see most wall wart have only 2 pins ...
thanks
Old 7th September 2005, 04:18 PM   #2
schematic
Old 7th September 2005, 08:38 PM   #3
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
First: Why do you want to connect it to mains earth ?
Next: If you do, put in a resistor (10R or so) in series to earth....
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 8th September 2005, 08:17 AM   #4
that means I shouldn't do it, right?
i tried to power up the psu, but the fuse (2A fast) blows...
i have no idea what could it be, i'll try "debugging" each stage
shouldn't be errors in the schematic, i just copied from lm317 datasheet
Old 8th September 2005, 04:01 PM   #5
Jan Dupont's Avatar
Do you use a single prim/single second. trafo as shown in the schematic ????
Old 8th September 2005, 07:04 PM   #6
thanks i found the problem
the transformer is a 0-115 115-0 -> 0-9 9-0
wired as 230 -> 18
everything works now, and it works great btw
thanks for the replies
Nicola
Old 8th September 2005, 09:29 PM   #7
Jan Dupont's Avatar
You're welcome
Old 9th September 2005, 03:43 PM   #8
destroyer X's Avatar
Default Va molto benne signore, il filo de colegamento inverso
Had mistakes in wiring...now the invertions were correct.
So, no more problem related ground....Va benne.
arrivederci
ciao
Carlo
My Youtube channel; http://www.youtube.com/user/destroyersoueu?feature=mhee
Quick question on the PP-C1 amp athos56 Tubes / Valves 13 20th October 2007 07:37 PM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 05:20 PM
Quick PCB question Piper Chip Amps 2 7th March 2005 11:59 AM
VERY quick question... Wyloch Multi-Way 2 3rd March 2005 05:34 PM
Page generated in 0.09025 seconds (72.26% PHP - 27.74% MySQL) with 11 queries
