need some trouble shooting help
Old 7th October 2002, 04:22 AM   #41
NickC is offline NickC
check the devices for counterfeit, mine where and this was one of the cause of the blowing of fuses
Old 7th October 2002, 05:53 AM   #42
sangram is offline sangram  India
Originally posted by Jean
<snip>I am thinking maybe tip2955/tip3055 keeps failing on turn on every time? My rail voltage is 36 volts, I remember reading with over 35Volts tip2955/tip3055 is not recommended.
Hello, I thought the output transistors were something different? Well, that is definitely a possibility. Remember your rail voltage is actually 72 volts, not 36. AFAIK TIP 3055/2955 have a Vcc max of 70 volts. Bad news, could be the cause.
I suggest before putting in the output transistors check the biasing voltages again. I would still look for Q9 and Q4 to be defective under loaded conditions.
Edit: Also check your input BC546 transistors, all three of 'em. If R6 has no current through it (therefore, 0 volts drop), maybe one of the input transistors isn't conducting properly. A little bit of DC in the input can cause one of these to implode...
need some trouble shooting helpHide this!Advertise here!
Need help in trouble-shooting my AES Sixpacs amp andy2 Tubes / Valves 2 12th January 2007 10:52 AM
Op amp trouble shooting Bose(o) Chip Amps 13 1st April 2005 08:37 PM
trouble shooting my DD receiver kslim Solid State 0 1st December 2004 01:21 AM
Help trouble shooting Christof Tubes / Valves 11 1st September 2004 03:27 AM
Trouble shooting help NerdMike Solid State 2 29th September 2002 01:34 AM
