Hello thanks for reading,
I have found the impressive looking diode which has a "Forward current vs. recovery time" response just like a tube! http://www.fairchildsemi.com/ds/IS/ISL9R8120P2.pdf Unfortunately this diode is rated for high current amps (like 8 amps). I require a diode with these characteristics as a replacement for 1N4001/Germanium 1N34A or standard 3mm LED (used as diode). Does anyone know of a diode that has these same charactistics that are suitable for my low current requirements? I am looking for a new type of diode (smooth transition/soft recovery) for the valve like clipping. Thank you for your help, GrantsV |
#2 |
Probably one of the small shottky diodes, BAT 42?
#3 |
Thank you! I have looked at the spec sheet and this does look promising:
http://www.farnell.com/datasheets/45257.pdf Forgive my ignorance, but these shottky diodes are all new to me coming from the land of traditional SI, GE and LED's as clipping diodes! Are these a cousin of silicon diodes? |
#4 |
Building guitar distortion?
#5 | |
#6 |
Thank you for the explanation.
Yes I am building guitar distortion but am unhappy with GE diodes (they have a nice soft recovery, but are too distorted being only 0.3v). LED's have a much better crunchy breakup at their clip range of 1v+, but they have a horrible harsh un-tubelike recovery. This means that with LED's I get solidstate fizz when the note dies off to clean. I am looking for a non-guitar mainstream diode for a tube like breakup. Thank you again for your help, GrantsV |
#7 |
So why not put GE and LED/SI in series?
#8 |
Hello,
Could you please explain how chaining a GE and LED in series would work? I understand that the forward voltages are added together, this results in a forward voltage of diode1+diode2 required to clip so chaining GE and LED would reduce my distortion and increase headroom. But which diode would clip when that clip voltage is reached? Both together, or the lowest voltage diode first? Thanks for your help, GrantsV PS. I like the compression and soft "turn on" characteristics of GE when gain is low, but I want to then have the crunch of LED's when the gain is raised up past just a subtle breakup point. |
#9 |
Any chance you could re-work the circuit to use an LED + phototransistor instead?
I don't know what it would sound like, but it would at least be a neat experiment. Wes
Do daemons dream of electric sleep()? |
#10 | |
Hi
LED with GE in series will have GE-like soft turn-on. When they both clip their on-resistances add on. LED's on resistance is low, GE on-resistance dominates. Quote:
If so, you could give four or five GE diodes (1n34?) in series to have soft cliping at 1.2-1.7V and this chain parallel with one LED (1.8-2.2V hard clipping). Anyway this can be lots of experiment and fun. Resistor-diode ladders may also play nice. This way you could tailor virtually any usable distortion curve, symetric or asymetric by changing values of resistors. |
| CD Transport: Laser Diode Guru?? HELP!!! | bear | Digital Source | 44 | 20th August 2009 06:40 PM |
| Tube rectifier to diode | bereanbill | Tubes / Valves | 19 | 19th May 2009 11:37 PM |
| DO-35 diode inside vacuum tube ? | pjp | Tubes / Valves | 11 | 9th February 2009 02:06 PM |
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| Page generated in 0.10239 seconds (78.38% PHP - 21.62% MySQL) with 11 queries |
