Old 7th September 2005, 12:15 AM   #1
tlf9999 is offline tlf9999  United States
Account Disabled
Default Ultra-High performance OpAmp-based MOSFET Power Amp
Got you, didn't I?
Well, enclosed is a conceptual design of a power amp using an opamp front end.
I have always wanted to see how well they will perform and how different they are from discrete designs. so here is my attempt and your comments are welcome.
Two issues that I had to deal with in this design:
a) insufficient voltage gain for high power applications: opamps run off low rail voltages. to solve that problem, I had to add a voltage gain stage consisting of Q1/Q2 and associated resistors.
Rather than driving them from the base, I decided to drive them from their emitter so that I can apply nested feedbacks.
b) stability: to get this thing to stable, I have to introduce local feedback and global feedback. thus the nested feedback here.
One really good thing about this amplifier is its clipping behavior: it is really soft, , un-SS like.
Also, most of the harmonies are 2nd and 3rd.
Now, the bad things:
a) significant phase shift: I haven't been able to find the cause of it. the amount of phase shift doesn't seem to change with the opamp used or mosfet's used.
b) relatively large thd: usually in the 1-1.5% range, unless you dial up the bias current to over 250ma.
Please let me know what you think of it and how you would improve it.
Old 7th September 2005, 12:25 AM   #2
Account Disabled
here is when it is overdriven.
Old 7th September 2005, 12:46 AM   #3
Account Disabled
on the issue of distortion, you can reduce it by a) running the driver stage at high current (how about 100ma?) and b) introducing some negative feedback here by using connecting resistors between base and collector of Q4/Q5. I used two 33k resistors there and it substantially reduced thd.
Old 7th September 2005, 12:57 AM   #4
Account Disabled
Hi tlf9999,
long way to go down this path before it fits the title I'm afraid.
Let's see.
I like that R1 very practical. The OP amp gain is 10 in a local loop as long as a low Z source is connected. Why a local loop here, it wastes so much that could be applied globally and wastes thePSRR improvement of having all that gain before an injection point.
emitter drive is not so good for loading on the chip and current limiting following stages.
how about nesting the discrete part and save the rest for global NFB should give a far better result.
Greg
Old 7th September 2005, 12:59 AM   #5
CBS240 is offline CBS240  United States
CBS240's Avatar
You could try to eleminate Q3 & Q4 and turn the FET's around where the output is from the drains instead of the source, you can get rail to rail operation then, and eleminate a pole in the process. Place a pot across R4 & R6 to adjust bias? How does it work without R2 and just using global feedback? Any miller compensation needed? I'm sure other manipulations might also work. Shouldn't a ground be between V3 and V4?
All the trouble I've ever been in started out as fun......
Old 7th September 2005, 01:16 AM   #6
Account Disabled
yeah. so that I don't have to deleted it or add it in case I wanted to change its value. This way, a sufficiently large R1 just means it is not there. So are thos 1ohm resistors. convenience, nothing else.
unless you can get it stable with just global feedback.
that's why there is R5. the chip pushes about 4ma maximum, within its output capability I hope.
only if I could get it stable.
I have never had any luck with cfp type output stages, especially in a mosfet configuration. tough to get it to stablize.
bias is done via R7. R4/R6 in part controls the gain on Q1/Q2.
unstable.
probably.
no. you can, however, put two capaitors on the base of Q1/Q2 to improve the gain of Q1/Q2 and psrr as well. But it is not a have-to-have for this excercise.
Old 7th September 2005, 01:27 AM   #7
CBS240's Avatar
Hmmm how about a nested feedback resistor from output to where R4 & R6 are connected and a divider resistor from there to ground? or is this what guru was talking about. Don't know if that will help stability. Generally I haven't had much luck getting a lot of stability from an AB biased feedback pair drivers...Q2,Q3 : Q1,Q4 although it can be done, not my personal favorite. Lots o' gain though.
Old 7th September 2005, 02:39 AM   #8
Account Disabled
Hi tlf9999,
"that's why there is R5. the chip pushes about 4ma maximum, within its output capability I hope."
Howsat? Looks more like 12mA to me given 15V supplies for the chip - a lot for the following stages to deal with and also your chip supplies.
Try grounding the junction of R4,R6 and running a feedback loop back to the top of each. Then go in from the chip to the bases for a high Z chip load. Then you need to work up the output nested loop and the global loop (having relieved the chip of it's local loop).
Your baby
greg
Old 7th September 2005, 03:47 AM   #9
CBS240's Avatar
If you do what Greg suggests, don't forget to take global feedback to neg input because the output phase will be reversed. and maybe Vin to the pos input.
Old 7th September 2005, 08:28 AM   #10
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
That soft-clipping behaviour is just a side effect of very low open-loop gain.
can I use this transformer to power the opamp based preamp? zome Parts 3 16th June 2009 11:27 PM
Opamp based power amp lumanauw Solid State 14 8th October 2007 05:46 PM
opamp input based power amps sparkle Solid State 38 11th May 2007 08:04 AM
Opamp based MOSFET amplifier design ronybc Solid State 33 28th July 2004 05:48 AM
high performance regulated supplies for power amps jez Solid State 14 5th January 2004 03:22 PM
Page generated in 0.11864 seconds (82.49% PHP - 17.51% MySQL) with 11 queries
