#41 | ||||
Well, at first I was stunned in silence with mastertech's post. Then, after Duo's post (who I agree with here !!), wondering how old mastertech is.
The obvious technical contect of previous posts in this and other threads makes it difficult to believe mastertech is only trying to help given the tone of the offensive post ... Quote:
-Chris |
#42 |
Hi there anatech, nice to see you.
Well, let me get two things off my chest: First, really, I don't like to argue or fight all that much, I think mastertech and the rest of us probably just had some slight miscommunication here and there which can be worked out. Second: I don't feel the significance of age in knowledge or experience that much. I understand that there is a connection; however, it's not a perfect connection... Would you like to take a guess at my age?? I wonder if my answer might surprise you???
-- Duo, W1ngs, VA7MON, and lesser known handles. -- -- http://www.w1ngselectronics.com -- My Work and Projects -- |
#43 |
Hi Duo,
I'd rather not have a fight either. The tone of the post that upset me wasn't well thought out and seemed a rather young or inexperienced thing to do. I do not have a lasting problem with anyone but had to make a point. Yes, miscommunications do occur. I've had them. As for your age ... no clue and it does not matter. Maturity matters more. Bettcha you don't know how old I am. Not that it matters either. If you are young, and well versed in the field, young age can be frustrating as few seem to take you seriously. That much I can say. I believe that some experience is important before one assumes a certain tone. Not that it will excuse the writer completely. At least there is a body of knowledge the writer is working with. I am not inferring anything here (to avoid insulting anyone). Anyway, back to the thread. -Chris |
#44 |
I must say, well said.
For the record, I'm eighteen, and believe me, it is a task delivering solid proof of my experience and work to some slightly stiff minded people. But certainly, the tone is what caught me as well. Thanks. -back to the post.
#45 |
Heyyy... I'm 25...
I've friends from far below and above my age. Luckly.. I find TIP142 & TIP147 complementary darlington pairs in the local market. These devices should perform better than those MJE13005/2N3055/HOTs ..right? Then contacted a friend of mine (who have a digital camera) to took this pic. Because... The labels on 'ST' make MJE13005s from MOROCCO are LASER carved. The TIPs are also 'ST' make from MOROCCO but the figures are printed instead. Are these fakes...? the pictures shown in Is this fake, it blows too much easy for a rudged TIP36 transistor makes more confusion. Do I need the Hammer test to reveal the truth...? |
#46 |
These look real to me. I am no expert on this but I have seen quite a few of these devices and they look like the ones you have here. I bought some TIP141/146 pairs from Mouser and I am not too happy about being gyped. The 146's are from Mospec and they are genuine. But the 141's are fakes. They are so fake that I knew they are fakes the moment I took them out of the pakage. I am not at home right now so I can't show a picture, but this was confirmed because 3 of them died under conditions where they most certainly shouldn't have. None of the 146's failed.
All the trouble I've ever been in started out as fun......
#47 |
I have about 100 2N3055s that i got out of a water cooled array used to drive an argon laser. Can i do something cool with them?
I figure i could a power amp for a sub, of practice electronics with them. Thanks for the help |
| four transistor emitter follower (diamond buffer) as power output stage? | capslock | Solid State | 101 | 15th March 2013 07:25 PM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| preamp output stage resistor from output to V- ? ? | Bernhard | Solid State | 4 | 19th October 2007 02:55 PM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| Hybrid tube front end and transistor output stage | Original Burnedfingers | Solid State | 6 | 4th April 2004 11:28 PM |
