Here's a good power amp fault - Page 3 - diyAudio
Old 11th September 2005, 02:45 PM   #21
anatech is offline anatech  Canada
anatech's Avatar
Hi andjur78,
I've also seen that conductive glue. It is the cause of the corrosion as well. You should find that it will chip away for the most part. The plyable stuff needs to be cut and yanked out. I bet that's your problem.
I remove this whenever I see it. The darker brown it is, the lower the resistance tends to be.
-Chris
Old 11th September 2005, 03:06 PM   #22
Send a message via AIM to DigitalJunkie
I second all the comments on the brown glue.That stuff is bad news.It always causes me problems,especialy when it's old.
There's a similar yellowish kind I've seen a few times,but havn't noticed any problems with it (yet).
Old 11th September 2005, 03:53 PM   #23
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
I remember a similar fault in a big mixing console. Turned out it were the input caps.
/Hugo
Old 12th September 2005, 02:21 AM   #24
The caps dont actually look that bad. I have had seen the leaking (powdery) electros before, but these "look" ok. But when is a cap really a cap? Maybe these are cheap derrivitaves of the real electrolytic capacitor as we know (have known) it??
(I,m sure there would be a website dedicated to electro caps and brands out there somewhere)
I don't know exactly what that brown gunk is but it sure does show up in alot of audio gear that has been made in China .
All the AMC stuff I have seen over time uses this glue around the base of caps and Xtals. "Well done" for Welltronics!!
...maybe it is some kind of space age vegemite that astronaughts use on their sanwiches
Anyway,I will clean the pcb, replace all electros and reassemble it this week. Then its soak test time again.
Stand back...
Old 12th September 2005, 12:11 PM   #25
anatech's Avatar
Hi andjur78,
The glue is used in PCB manufacture to hold the heavier components in place during soldering. I've seen it on Sony and NEC made PCB's as well. I think this is your only problem. Other components should be fine as long as the lead isn't corroded too much.
Someone once told me this wonderful stuff was called "Sonybond". I can't say for sure, but I know that Sony never admits to anything when they make a mistake.
-Chris
Old 19th September 2005, 08:41 PM   #26
Ok for all who are interested: It is not the caps!!!
I Replaced all electros, cleaned the pcb and went over every solder joint and the fault is still exhibited.
Now I will home in on the front end differential pair.
If anyone is interested in posts of the ongoing servicing of this amp please let me know and I will continue to post any updates.
Old 19th September 2005, 08:58 PM   #27
anatech's Avatar
Hi andjur78,
Well, I'm always interested. I was hoping it was the "glue". That would be a cheap fix.
-Chris
Old 19th September 2005, 09:03 PM   #28
Netlist's Avatar
Originally posted by anatech
Hi andjur78,
-Chris
Me too as I was hoping for the caps. Up to the semiconductors.
/Hugo
Old 19th September 2005, 09:57 PM   #29
I am interested also....
Old 19th September 2005, 11:55 PM   #30
anatech's Avatar
Should we start a pool? I guess it's too late now.
It looks like a junction breaking down in a transistor. Normally a 2SC458 is at the bottom of that, or an early J-fet. There are none of these here.
-Chris
Marantz DVD player power supply fault? slimecity Digital Source 1 1st January 2009 09:57 AM
Oscillation~ Pre or Power's fault? hajame Everything Else 1 1st October 2007 09:50 PM
Oscillation~ Pre or Power's fault? hajame Solid State 1 27th September 2007 10:16 AM
Audiolab 8000A fault in power amp side - HELP! carribey Solid State 17 25th April 2006 06:23 PM
NAD 214 Power Amp Fault Bennyboyph Solid State 3 14th May 2005 02:33 AM
Copyright 1999-2017 diyAudio
