Purpose of this capacitor in discrete amplifier?
Old 5th September 2005, 12:19 AM   #31
andy_c is offline andy_c  United States
Banned
Here is my version of the two-transistor current source.
As you can see, the two transistors aren't visible.
Always glad to be of help!
File Type: png twotransistorcurrentsource.png (200 Bytes, 79 views)
Old 5th September 2005, 12:39 AM   #32
amplifierguru is offline amplifierguru
Account Disabled
Hi Andy.
Very funny
Out of context mate. The post was about the PSRR of various diff'l tails. everyone knows what a 2BJT CCS is, but dimitri had to highlight a partly shown piece of the schematic. that's all. It was simply an experimental lash up and had nothing meritorious in itself to display so there was considered no need to show it.
cheers,
Greg
Old 5th September 2005, 12:43 AM   #33
mastertech is offline mastertech  Australia
Banned
with diode is not as precise as with transinstor base connected to collector
high precision is mastertech guys
cheers
Old 5th September 2005, 12:58 AM   #34
Account Disabled
Hi Mastertech,
The diode in question was added to the 2BJT CCs for a reason - I needed a 1.2V active component across the 1.2k so I built up the BJT Vbe junction voltage with a diode. Why? because the CCS is temperature comp as well and either the diode or BJT were to be relocated to the heatsink. As the thermal comp required was half that of a std BJT I added an equal but non thermally connected component with a much smaller dynamic impedance than a resistor which would dramatically impair the CCS performance.
So I got my 2mV/degree in 1.2V, temp comp CCS.
Clear as mud.
Greg
Old 5th September 2005, 01:02 AM   #35
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
so the CCS current can be calculated as Ube plus Diode drop divide on 1200 Ohms
What about thermal stablity?
oops, you are fast - but why 2 mV/deg, 2 pn junction - 4.4mV/deg
Old 5th September 2005, 01:20 AM   #36
Account Disabled
Hi Dimitri,
I wanted a CCS that had a -Ve tempco of half that of a BJT so put the diode in the sensing leg and EITHER the sensing BJT or diode can go to the heatsink while the other monitors ambient. Simple low cost solution! As you're aware the simple BJT CCS has a normal 2mv/deg tempco of output current , this was simply my way of halving it.
Greg
Purpose of this capacitor in discrete amplifier?Hide this!Advertise here!
Multi-purpose Power Amplifier domtw Chip Amps 22 23rd March 2009 02:18 PM
Discrete Class A amplifier for discussion. keantoken Solid State 11 17th January 2009 04:22 AM
Pre-pre; phono; pre line ;device discrete (bjt/fet) o op. amplifier GIPIONE Solid State 8 18th December 2005 09:09 PM
Discrete Subwoofer Amplifier Repair Hara Solid State 11 28th November 2005 05:48 AM
Purpose of Parallel Capacitor with AD811 I/V circuit? fastcat95 Digital Source 3 9th February 2005 05:09 PM
