So it is between the input grid signal of the first preamp tube and the ground?
B battobataaree Member Joined 2014 2018-01-25 9:00 am #21 2018-01-25 9:00 am #21 So it is between the input grid signal of the first preamp tube and the ground? ••• More options Share anatech Administrator Joined 2004 Paid Member 2018-01-25 1:16 pm #22 2018-01-25 1:16 pm #22 I can not/will not answer that without seeing your circuit. Why not look at some schematics of amplifiers similar to your own? Also, what exactly are you having a problem with - in your own words. -Chris ••• More options Share Prev 1 2 First Prev 2 of 2 Go to page Go Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
