hallo
I need a schematic of a good preamp Simple ,discreet parts. Sugestions? regards hoek |
#2 |
Have a look here:
http://myweb.tiscali.co.uk/nuukspot/...ainclone2.html The buffers, IC and discrete, can easily be modified for some gain. Particularly the one with the OPA627. You can replace that chip, which is rather expensive even if perhaps one of the best there is, with other quality chips. Carlos |
#3 | |
Hej as I am in love in the triplet of the transistors that peufeu has discovered, please try this single ended design. To minimise "memory distortion" (or as do we wish to call them?) the transistors work at constant power. The gain is slightly less than 10 times. The sound is very smooth and detailed. Please extremely care to use good quaality capacitors. You can use positive rail up to 30V and negative only -5V as well. This is the schematic of working circuit.
regards, Pawel |
#4 |
Carl Mart
Thanks for your response There is a lot of information on that site |
#5 |
Hy Padamiecki
Looks very interesting I will try this one thanks |
#6 |
I have built the 3 bjt discrete buffer this thread refers to (from Decibel Dungeon). I am very happy with it and have made my impression known to DD.
Carlmart says these buffers can easily be configured for some gain. Can he, or anyone else, please explain to me how to do this? Or maybe it would be better to build a preceding gain stage, or even to build a new pre, configured for gain from the start? |
#7 | |
could you please explain? because the circuit sent by me in this thread is not a buffer...
regards, Pawel |
#8 |
Thanks for showing interest. I was referring to the 3 bjt buffer found on Decibel Dungeon's website as referred to by Carlmart. (Found at this address:-http://myweb.tiscali.co.uk/nuukspot/decdun/gainclone2.html)
I have built it with 22uF Black Gate output caps and a different selection of transistors (by trial and listening) and find it simply outstanding. I would also be very interested indeed to try your design - in fact it looks like the perfect solution for me - but I cannot read the drawing clearly, and also I am not experienced enough to be able to calculate correct values for use with my +/- 16.8V power supply. If you could post a clearer drawing, that would be much appreciated, and any help in how to work out best values would be most welcome. Thanks, William. |
#9 | |
my proposition is to try Borbely's buffer
regards, Pawel |
#10 |
I would like to try peufeu's design, but I am having trouble making out the components at the bottom of the drawing you posted. Is that a trimpot there, and what is the value next to it?
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| wiring preamp outs on a preamp | bonsai171 | Solid State | 4 | 22nd March 2004 10:13 PM |
| Page generated in 0.09769 seconds (81.39% PHP - 18.61% MySQL) with 11 queries |
