Old 28th August 2005, 12:09 AM   #1
jackinnj's Avatar
Default Sumo Polaris 310
Here's a PDF of the schematic -- I blew out one channel so had to trace it out. The transistors used inthe original are 2SK405 and 2SJ115 for the output stage, and 2SA1360 2SC3423 for the va stage.
Old 28th August 2005, 02:56 AM   #2
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
How does it sound???
Old 28th August 2005, 12:57 PM   #3
jackinnj's Avatar
the one channel which is working sounds spectacular -- I have owned this amp since the 1980's but it was used by my son with a set of Swan's and I think that he overdrove it.
the THD at 1kHz around 60W was 0.02% if that matters.
Old 29th August 2005, 02:55 AM   #4
jackinnj's Avatar
replaced the original MOSFETs with IRF'S -- initially the distortion was quite high, 0.50% but by adjusting VR1 and VR2 both channels match at 0.01% to 0.02%.
Old 29th August 2005, 12:13 PM   #5
If you are replacing the original parts types, you might try using a better chip for U2 and a better cap for C9.
A 741 is hardly a low-offset IC, and something like an LF411 might be a better option. There are other types, but that might be easier to find and cheap too.
DC servos are used to eliminate the feedback large cap on the gain. But that doesn't mean that no audio is passing through any caps, as it is going through the servo cap C9. This cap should be a high quality one, preferably a film type. As that value is a bit high for such a type and you might have some trouble finding pcb space to hold it, a better eletrolytic should do it.
Carlos
Old 29th August 2005, 01:11 PM   #6
jackinnj's Avatar
Carlos
Yes, I just wanted to get the amp up and running first -- the opamp's bypass caps are far removed from the opamp itself -- meaning that they are useless -- I can get a non-polar electrolytic and byass it with 100nF MKT for C9 --
anything more is gilding the lilly (but I am tempted) -- it sounds good, the distortion at low levels is 0.03% on both channels, and at high levels a little over 0.01%
Old 29th August 2005, 02:41 PM   #7
Getting the amp running is certainly the most important thing.
I didn't refer to the opamp's bypass caps, but C9, which is in series with the chip's output. Changing the chip might bring the greatest gain, but do that using a chip socket, if it's not already provided for.
For the cap it might be better trying several types and values.
These two mods I would not consider gilding the lilly, as they are part of the feedback. If you go for it, change the chip first and then try different cap values and types.
Or write to Buongiorno, who designed the amp and might have something to say on potential improvements. That might be the wise thing to do.
Carlos
Old 30th August 2005, 09:54 AM   #8
djk is offline djk
djk's Avatar
Bongiorno did not design that amp, and does not like FETs.
Old 30th August 2005, 11:11 AM   #9
Tube_Dude's Avatar
Hi
Something is wrong in the schematic , with C9 in series with the output of the Op Amp , the op amp can't do anything to control the offset...
Jorge
Old 30th August 2005, 01:05 PM   #10
jackinnj's Avatar
I didn't really bother to check the value of the compensation caps in the feedback network -- I'd have to unsolder the part to get to it.
with respect to C9 -- I will take it apart again and retrace
Sumo Polaris Mod. 310 W/ Ch. failure. calentz Solid State 12 29th January 2010 12:34 AM
SUMO Polaris Class A/B Stereo Power AMP (New to the Board) thecavernut Solid State 12 15th November 2009 11:15 PM
Sumo Polaris, Muse 150's, Threshold S/150-2 joegio Swap Meet 0 4th May 2009 05:08 AM
sumo amp steven344 Solid State 1 20th May 2006 08:30 AM
Page generated in 0.10521 seconds (78.44% PHP - 21.56% MySQL) with 11 queries
