Sumo Polaris 310 - Page 3 - diyAudio
Old 5th September 2005, 05:42 PM   #21
jackinnj's Avatar
top side photo:
i still have yet to re-remove the amp pcb's -- but here's a top side scan
Old 6th September 2005, 01:04 AM   #22
djk is offline djk
djk's Avatar
R27 is clearly 1 ohm, not the 10 ohm marked on your drawing.
Old 6th September 2005, 12:58 PM   #23
jackinnj's Avatar
Default with DJK's comments
here's an updated PDF -- I don't think that the MPW3700 is available anymore -- 200VRR in DO41 case -- the MPN3700 is available in TO-92.
I changed cr1, cr8; placed the RC combo from the servo amp in parallel;changed r27 to 1 ohm; flipped the power transistors -- (these are shown as IRF parts although the originals are Hitachi);the VAS transistors are shown as 2sb649,2sd669 - not the originals which are "unobtainium".
DJK -- if it is starting to look correct we should have an administrator cancel the original thread and just use the correct schematic ab initio
Old 6th September 2005, 03:32 PM   #24
Default Re: with DJK's comments
Can you check again of diodes CR6/CR7 are not directly between pins 2 and 3 of U2? Those are protection diodes to avoid IC clamping, so it would make more sense if there was no resistor (R4) in between.
Carlos
Old 7th September 2005, 01:20 AM   #25
SkyChu is offline SkyChu  Taiwan
The C3/R9/R10 is different with C7/R33/R34. Myabe is like the attached circuit.
Sky Chu
Old 7th September 2005, 11:37 AM   #26
jackinnj's Avatar
yes, thanks for pointing out this inconsistency, connect like this:
Old 21st July 2007, 10:36 PM   #27
EchoWars's Avatar
Going to dig this thread up, as I may be fooling with one of these shortly...
If VR1 is controlling bias current, what is VR2 doing?
jackinnj, might you expound on your notation for these pots ('Key=A' and 'Key=Space 50%')?
With the 0.25 ohm source resistors, I assume that matching of the outputs is not as critical as it might otherwise be?
Old 22nd July 2007, 03:10 PM   #28
Send a message via AIM to zerohead_ak47 Send a message via MSN to zerohead_ak47
error
Old 22nd July 2007, 03:14 PM   #29
sory i dont see
Old 22nd July 2007, 05:11 PM   #30
r1 r2 r3 c1 wrong check pls
Sumo Polaris Mod. 310 W/ Ch. failure. calentz Solid State 14 21st December 2013 02:40 PM
SUMO Polaris Class A/B Stereo Power AMP (New to the Board) thecavernut Solid State 12 15th November 2009 10:15 PM
Sumo Polaris, Muse 150's, Threshold S/150-2 joegio Swap Meet 0 4th May 2009 04:08 AM
sumo amp steven344 Solid State 1 20th May 2006 07:30 AM
Copyright 1999-2017 diyAudio
