howdy
I'm about to build Rod Eliot's DOZpreamp from his site. He states that transformer should be 16 V AC, yet the one I have is 20V AC so I need to recalculate values of R1 and R2 (100R). I thought of putting R1 120R and leave R2 100, am I right or someone please correct me... Heres Url: http://sound.westhost.com/project37.htm and pic of PS:
There is no spoon...there is a fork!!! |
#2 |
But it will work with bigger voltage too.
Please inform me if sucessfull or not..... i am not entirelly sure. nanabrother@yahoo.com good luck! Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine. |
#3 |
It will work with whatever value you pick for R1/R2, with higher entrance voltage there will be more current flowing through the BD139 to make voltage drop to 30v over R1+R2.
By choosing higher values for R1 and R2 you make life easier for the transistor, above 1 watt dissipation it will need a heatsink. Instead of a bit over 40Vdc on entrance, dropping to 30Vdc, with 20vac secondaries entrance voltage will be above 50 volts. The voltage drop over R1 and R2 will be around twice as high. If you wish nominal current level to remain at 50mA, R1+R2 need to be 400 ohms instead of 200. If you go for lower values you will need much higher power rating for R1 and R2. To drop 20 volts over 120+100 ohms it takes 91mA. Means R1 at 120 ohms needs a power rating of at least 1 watt. If you choose R1=200, R2 = 200 ohms, the minimum is 0.5 watt, and half the thermal load on the BD139. And choosing R1 as 200 ohms changes the corner frequency of the R1-C3 low pass filter to 0.36 Hz from 0.72Hz, even lower ripple.
Looks like Sponge Bob has killed another thread. |
| Resistor values | Valvomaniac | Tubes / Valves | 5 | 27th April 2007 04:50 AM |
| Resistor Values For L Pad? | kelticwizard | Multi-Way | 8 | 16th February 2006 01:41 AM |
| Resistor values | Stocker | Chip Amps | 3 | 4th May 2004 03:10 PM |
| Resistor values? | randytsuch | Chip Amps | 2 | 11th July 2003 01:08 AM |
| Page generated in 0.07421 seconds (71.70% PHP - 28.30% MySQL) with 11 queries |
