Just wondering if you guys think these two transistors are close enough to be compatible?
2SB1186A http://pdf.alldatasheet.com/datashee.../2SB1186A.html KTA1024 http://pdf.alldatasheet.com/datashee...C/KTA1024.html They are part of an amplifier's driver circuit. It originally had the KTA1024, but it fried. And I have a few 2SB1186A's on hand. I know the datasheet for the 1186A doesn't show pinout, but it's the same as the KTA1024. I think they are close enough, but I'm no transistor expert and want a 2nd opinion.
#2 |
One of them have a very nice small capacitance...but a very small colector to emitter current.... this one is the KEC.
The Other one has enormous capacitance, and a very good colector to emitter current. Removing the KEC and placing the other will be better than the oposite....this will depend of your application. I do not think they are perfect substituted one for the other...only in very special cases of very low current applications. Those transistors are not made to audio applications they are more adequated to power supply switching purposes. Yes, they can work to audio, as one of them are already working, but some guys have the idea that the audio produced is not so good as can be when using standard BJTs, custom made for audio frequencies. If you decide to replace, please inform the result.... as i have some doubts....lets listen other guys in advance. nanabrother@yahoo.com regards, Carlos
My Youtube channel; http://www.youtube.com/user/destroyersoueu?feature=mhee |
#3 |
Yeah, I notice 4-5pf vs 30pf is a pretty big difference.
This will be for low current application for voltage control. I think I'm going to try it replacing the KTA1024 with th B1186A . I'll report back.
#4 |
But tell me some, after replacement.
There are always something to learn...will work...but i will be happy to listen if you could perceive some advantage or the opposite. regards, Carlos
#5 |
I replaced the transistor and the amplifier plays audio, but buzzes then goes into protection mode.
So I either have something else wrong. Or something about this transistor makes it incompatible.
#6 |
Check to see if you are now a radio station.
-Chris |
#7 | |
#8 |
RF. You have an AF amp. Is it now an RF amp also? (Oscillation)
-Chris |
#9 |
A better choice would be a 2SA1124
get the data sheet through Digi-key and compare. ft is higher but the rest is very similar
Doug We are all learning...we can all help |
#10 | ||
Actually, yes! Just about .5 seconds before it shuts down it oscillates. It sounds like it's about 60Hz. I have a scope at my disposal, should I take a reading of it? Is there a way to stop it? And how did you know that was a possibility? Was it the high Cob of the b1186a? also, is your avatar a quote form That 70's Show? Quote:
Thanks, everybody for your help so far.
| 12AT7 vs 12AU7 (interchangeable?) | jn2630 | Tubes / Valves | 5 | 12th January 2008 05:34 AM |
| Transistor variants - interchangeable? | tigger01 | Parts | 22 | 6th July 2007 10:07 PM |
| transistors | reddish75 | Solid State | 17 | 29th November 2006 05:48 PM |
| PD2150 impedance, are 4ohm and 8ohm re-cones interchangeable? | Puggie | Subwoofers | 2 | 28th March 2006 04:24 PM |
| tweeters interchangeable? | Craig | Multi-Way | 6 | 3rd December 2002 07:23 AM |
| Page generated in 0.19179 seconds (51.74% PHP - 48.26% MySQL) with 11 queries |
