Old 15th September 2005, 04:29 PM   #21
tarnationsauce's Avatar
Send a message via AIM to tarnationsauce Send a message via MSN to tarnationsauce Send a message via Yahoo to tarnationsauce
Originally posted by Eva
It's not desirable to mix different transistor models in differential pairs since that would degrade performance. It would be a good idea to replace the other KTA in case you haven't done it yet.
Thanks for mentioning that. But I already thought of that. I figured since they are all >$1 I'd replace them all and make the pairs matched. I even did the other channel so the channels would still be matched.
Old 14th August 2007, 01:20 PM   #22
Default Zener Diodes?
Hi, I hope you've given the wrong part number - the 1N4148 is a small signal diode - NOT A ZENER.
I've just fixed a power amp with similar symptoms, but the problem turned out to be the output stage bias adjuster - it went open-circuit once it warmed up from the current flowing through it and turned all 8 output devices hard on.
Unfortunately, the power fuses are the wrong side of the smoothing caps, so the caps discharged through the output devices and usually at least half of them would go dead short and the resulting voltage on the output would trip the protection circuit.
I remember when the idea of using a vbe multiplier for bias was first around ( the late '60's ) and the advice was to put the pot in the voltage divider chain so the bias would turn off if it failed. Seems like someone forgot...
Graham.
Old 14th August 2007, 07:22 PM   #23
unclejed613's Avatar
ramping up DC? sounds like:
a) bad DC feedback capacitor (or DC servo)(after reading the text in the picture above, dc servo)
b) bad diff amp (LTP) transistor
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
12AT7 vs 12AU7 (interchangeable?) jn2630 Tubes / Valves 5 12th January 2008 05:34 AM
Transistor variants - interchangeable? tigger01 Parts 22 6th July 2007 10:07 PM
transistors reddish75 Solid State 17 29th November 2006 05:48 PM
PD2150 impedance, are 4ohm and 8ohm re-cones interchangeable? Puggie Subwoofers 2 28th March 2006 04:24 PM
tweeters interchangeable? Craig Multi-Way 6 3rd December 2002 07:23 AM
Page generated in 0.09449 seconds (70.08% PHP - 29.92% MySQL) with 11 queries
