best small signal FET?
Old 24th August 2005, 11:20 AM   #21
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Mr Carr,
please click HERE!
Cheers Michael
Old 24th August 2005, 12:19 PM   #22
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, Jcarr,
If I'm not mistaken, in the development process, you also consider the topology of 3stages (standard) besides the folded cascode topology. At that time you said you prefer the 3 stages. What happened to the 3stages version?
I've got a technical question. Somewhere here, it is said that it is not wise to use Jfet "starving" of current.
If I've got a Jfet with Idss of 2mA, how much is the "starving" threshold?
Old 25th August 2005, 04:01 PM   #23
Marlowe is offline Marlowe
Originally posted by Charles Hansen
Hi Jonathan,
Babelfish won't translate the entire PDF. Instead, open the PDF in one window. Then use the "Text" tool in Acrobat to select text. Copy and paste into the window with babel.altavista.com running in your web browser. (I think the word limit is 150 words at a time.) Then copy those results (one chunk at a time) into a word processor or text editor.
Charlie Hansen
Google Language Tools are another good choice for multi-language translation.
http://www.google.com/language_tools?hl=en
Here's looking at you, kid.
best small signal FET?Hide this!Advertise here!
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 08:51 PM
small signal transistor icko Solid State 13 13th May 2009 02:01 AM
Best small signal BJT for DIY audio? OliverD Parts 1 5th April 2009 05:35 PM
Small signal amp. mantisory Solid State 17 8th August 2008 01:33 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 03:07 AM
Copyright ©1999-2017 diyAudio
