Hello All,
Here is the schematic of my power amplifier. Its highs are not crisp rather dull, bass is not tight and vocals are muddled. Can any body tell me what is the problem with this amp? And how can I mod this amp to get crisp highs, tight bass and clear vocal? Thanks, Nageswar
routhun |
#2 |
Hi Nageswar,
Is this your design? Neat looking… At first glance it looks like you’re using current mirrors as the VAS. Interesting way of using a single diff. and a class AB VAS stage. It appears that the bias is set by the current source of the differential. However every mirror is like another stage in slack time. The time it takes to turn on a transistor and turn it off adds delay which can cause some dulled highs when inside the feedback loop because of the compensation needed to keep from oscillating. Is there a reason for using two sets of VAS transistors instead of 1 larger one? What is the reason you use class ab VAS & mirrors instead of class A w/current source? Trade offs? Interesting cutoff circuit.
All the trouble I've ever been in started out as fun...... |
#3 |
looks like mackie design
#4 |
Maybe this amp were designed to drive subwoofers ?
#5 |
Hi Nageswar,
Okay, it's a Korean schematic and / or design. Confirm the tail current is high enough for starters. Same for the vas input transistors. -Chris |
#7 | |
I see four areas that might be dealt with: 1) The zobel between the collectors of the LTP. 2) The two capacitors C409 and C411. 3) The unnecessary VAS dual transistor. 4) The capacitor bypassing R469, which IMHO might be smaller and a film type. Carlos |
#8 |
Hi CBS240,
This is not my design, it is the schematic of the power amplifier of my Harman Kardon AVR520 receiver. When I compare the sound of this receiver with my Nikko NR-1019 receiver I found the sound from AVR-520 is rather dull. Initially I suspected the preamp in this receiver, so I drove this amp from the Nikko's main out. There was a little improvement, so I thought of modding this amp could bring its sound to comparable to Nikko. I could not think of any mods of my self so I posted on this forum. I don't know why they choose certain configuration like dual VAS transistors and other tradeoffs. But I would like to start with simple mods as suggested by carlos, and move to complex mods suggested by you. Carlos can you suggest me what would be the best value for C415 (the capacitor bypassing R469) and values for Zobel network between collectors of LTP and capacitors C409 and C411? Thanks, Nageswar
routhun |
#9 |
Hi Nageswar,
I sold an NR-1019 to a friend years ago, he still has it. A really nice sounding rcvr from years gone by. -Chris |
#10 |
I was being very general in assuming that this is a design in progress. Not to say that it can't be improved, obviously. But this is where you might get into the 'design you own' mode....best way to learn though.
| Electrocompaniet EC1 help requested | BEARD | Solid State | 26 | 1st November 2008 10:33 AM |
| Hafler XL280 mods gain/low frequency cutoff problem | HaflerFreak | Solid State | 29 | 6th September 2007 11:55 PM |
| 70l Box Suggestions Requested | nayr2 | Subwoofers | 7 | 25th October 2005 05:52 PM |
| Problem with T-amp Mods | kyban | Class D | 11 | 9th August 2005 07:11 PM |
| Help requested: broken amp | nowater | Solid State | 20 | 15th August 2004 07:26 PM |
| Page generated in 0.10701 seconds (80.37% PHP - 19.63% MySQL) with 11 queries |
