Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 19th August 2005, 12:00 AM   #11
anatech is offline anatech
anatech's Avatar
There may be a transistor muting circuit. It would be triggered from an AC detect circuit. Look for a single diode from the secondary to a cap around 1uF. Check the ripple.
-Chris
Old 19th August 2005, 02:20 AM   #12
gmilitano's Avatar
-Chris
The preamp section of the 3020 is not the same as the 1020 so the schematic does not help much.
Checked the regulators and the voltages seem ok +24 and -21, a bit of a bigger difference than I expected, but I don't think the few volts are the problem.
It does not make sence why both channels are out, so some sort of muting transistors may be the problem. However, without the schematic, I can't figure out where the muting circuit is.
I had planned on upgrading the pot and capacitors .. perhaps its time to get something newer.
Old 19th August 2005, 02:26 AM   #13
anatech's Avatar
Hi GG,
Sorry, this would be much easier wit ha schematic. Look for 2SC2878 transistors - classic muting transistors. If you find a bad one, they must be replaced by the same thing.
However, I strongly feel you have a supply voltage fault. Possibly affecting the muting circuit (if there is one).
-Chris
Old 19th August 2005, 02:40 AM   #14
gmilitano's Avatar
Hi GG,
-Chris
Measurements relative to the ground on the chassis:
DC +32.4 and -31.9
Orange (zener?) diode in -20.3V, out -2.5V
Regulator transistors <23.4, 31.6, 24.0> and <-20.3, -31.2, -20.9>
Blue diodes, most less than 3V (some near zero?) and the others at
about 20V. Will have to look at these more closely.
I think the orange diode drops the voltage down to 2.5V for the LED
power indicator which is right by this orange diode. This is the only
thing that makes any sence since there is only one of these orange diodes.
To me it looks like the power supply is functional. I will have to look at it again tommorow with a clear head.
Old 19th August 2005, 11:56 PM   #15
gmilitano's Avatar
This is very weird. If I pull any one of the two fuses, the problem remains the same. That is a very very faint signal with occasional loud pops. It does not mater which fuse you remove, as long as one of the two fuses remains in place. It looks like there is one fuse for the +AC and one for the -AC (center tapped transformer).
Does this mean that there is a short somewhere on the circuit crossing the +DC and the -DC?
Old 20th August 2005, 12:30 AM   #16
anatech's Avatar
Hi GG,
No, you are changing the supply from full wave rectification to half wave rectification. If you had a 'scope, you would see the ripple frequency go from 120Hz to 60Hz. Neat huh?
-Chris
Old 20th August 2005, 12:42 AM   #17
Banned
could be the volume pot!
Old 21st August 2005, 02:42 PM   #18
gmilitano's Avatar
I have to take that back. Most of the line amp section is similar. There is an extra transistor pair in the lineamp stage. However, I have a signal beyond that point so I assume there is not problem. The phono section is also a little different (extra transistor pair plus variable input capacitance).
The 3020 schematic shows only a preout. However, in addition to the preout, my 1020 preamp also has a high level preout. As far as I can tell, after the treble, bass and balance controls, the signal goes to the headphone amp and from there, it goes to the preout, high level preout and headphone. Now, there is no signal going to the headphone amp, but there is power, so I assume that the headphone amp is also functional. The headphone amp is also not shown on the schematic as the 3020 does not have one.
When I trace the signal back from the headamp, I get to another transitor pair which also is not on the schematic. I'm not sure what the purpose is of this transistor pair ... perhaps this is a muting protection circuit that kicks on for a few seconds when preamp is turned on that others have mentioned. However, this circuit is seperate from the audio mute button which is working.
Here are the details for the transistors (Q509 and Q510 which are not shown on 3020 schematic)
B231 (or 8231) two pins at zero voltage, pin marked "G" -10.7V
B221 (or 8221) two pins at zero voltage, pin marked "G" -9.7V
It is funny that the board is marked "G", typically for transistors, they show "C" "B" "E"?
Also, I have signals at the bass and treble controls. No signal at the balance control, but the balance control is connected to the transistor pair I just mentioned.
I guess the options I have are to try and bypass this transistor pair and balance control. If so, where should I pick up the signal (R537, R541 or R543). If I ran this signal into the headamp, I should still be able to use both the preout and high level preout, provided I don't encounter any more problems? Can those transistors I am thinking of bypassing be important?
Old 21st August 2005, 02:53 PM   #19
anatech's Avatar
Hi GG,
Now those sound like a muting circuit. There are probably junction fets. Desolder them from the circuit. You may need to short the source and drain pins if they are used to pass signal. Take a picture of the circuit before you pull them with a digital camera if you can.
The negative gate voltage would keep them in cut off. Things would be a lot better with a sensitive relay in this circuit.
So if you find the unit works with these bypassed, you have a problem in the muting circuit. Bettcha it's an open small capacitor used for AC detect. They may be using a set of contacts on the power switch for this too. Easy to check by looking at the switch.
-Chris
Old 21st August 2005, 04:13 PM   #20
gmilitano's Avatar
-Chris
Hi GG,
-Chris
Hi Chris,
Thanks for your help thus far. I am starting to think it is the muting circuit causing the problem.
Now, I have located a single diode close to these two transistors. The diode is at about -30V. However, the nearby capacitors are in pairs and 47uF. There are also some green mylar capacitors nearby, but also in pairs.
Aside from the AC, there are also two sets of DC wires hooked up to the switch.
If I opt to bypass the muting circuit, should I remove those transistors, or just leave them in place?
Thread Tools
Please help with NAD 1020 Pre-amp pureh2o Solid State 12 18th October 2008 09:39 PM
Preamp RFI problems Jonnyc Chip Amps 0 21st July 2005 03:25 AM
Fisher RS-1020 questions and problems Jeffy74 Solid State 0 18th April 2004 08:40 PM
kenwood KAC 1020 amp emarald Solid State 4 7th January 2003 04:30 PM
Page generated in 0.11798406 seconds (84.68% PHP - 15.32% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
