Old 12th August 2005, 08:27 AM   #1
Question Using Many Small Signal transistors for the output stage Update!!
Hello Everyone,
Not long ago I brought up the idea about using many small signal transistor in parallel for the output stage of a amplifier.
Someone said to try 1 amp small power transistors like the BD139.
I built up a test circuit with 6 BD139's paralleled in place of each power transistor that I am using.
As you normally use wire wound 5watt resistors on the emitter of each paralleled transistor to promote current sharing, this would mean that I would need 12 resistors to do the job.
As I didn't have them on hand or want to buy them just for this test, I decided to measure 12 lengths of cooper wire until I had 0.4 ohms for each length of wire. This would take the place of the resistors. By the Pic Attached you will see that I have wound all 12 lengths of wire on to one former in the middle of the test board.
I know that the heat sinks are too small, but I will be running each test for seconds not minutes, just to hear the effect.
So before I wire the board up, I decided to put a pic on the forum just in case it all goes up in smoke.
Old 12th August 2005, 08:36 AM   #2
Did it work ?
Cheers / Chris
Old 12th August 2005, 06:22 PM   #3
CBS240 is offline CBS240  United States
CBS240's Avatar
What if current in one wire inducting current in another next to it affects bias and current sharing? is this a possibility?
you could get an ordanary resistor and wind the wire around each one seperately...making wire wound resistors.
All the trouble I've ever been in started out as fun......
Old 12th August 2005, 06:24 PM   #4
large diameter coils have large inductance.
Will this affect your assumptions?
A zig-zag pattern on a non conductive former will have almost no inductance.
Alternatively, wind the coil using half the wire length in one direction around your former and then reverse the winding direction to finish the second half of the coil. A long small diameter coil wound on a 5mm wooden dowel will have less inductance than your 20mm square coil, still using the two direction trick. Each coil would then be self supporting and independant.
regards Andrew T.
Old 12th August 2005, 11:40 PM   #5
Hello Everyone,
When i connected it to my Amp the bias transistor and driver transistors in my amp went up in smoke in a big way and also one lot of the BD139's in parallel look like they bit the dust as well. Before I removed the output transistors, the amp had been working for months with no problems.
For this Amp I think I will run just 1 or 2 normal high ampage transistor on the output.
May build a low voltage single supply (10-16volts) amp to continue the tests?
Old 13th August 2005, 12:01 AM   #6
13DoW is offline 13DoW  England
Don't forget that the ballast resistor for each BD139 should now by 6x the value of the single ballast resistor on the emitter of the single power transistor.
If you kept the value the same then it will have little effect at the lower collector current that each BD139 is working at and might not prevent one of the BD139s from thermally running away.
I would stick with discrete resistors rather than messing around with all that wire.
13th Duke of Wymbourne
Old 13th August 2005, 12:17 AM   #7
I'd get some regular resistors and dump the jumble of wires. Looking at the circuit without knowing what it is it looks like some kind of inverter
Does the board simply have three leads and connect to the old amp's transistor pads, so that you have the amp board's individual emitter resistors AND the amp's old emitter resistors?
I would still scale the 6 individual emitter resistors up a little bit. I would also recommend individual base resistors on each transistors base. maybe 10 ohms or so?
Old 14th August 2005, 12:12 AM   #8
Hello Everyone,
Any advice is appreciated on this circuit, please keep your ideas coming.
Thanks for your replies.
Old 14th August 2005, 01:10 AM   #9
Ultima Thule's Avatar
Yes, trash that "ignition coil" and replaces with real resistors and I will look forward to take part of this thread!
Cheers Michael
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears"
Michael 29th January 2010
Old 14th August 2005, 01:23 AM   #10
tlf9999 is offline tlf9999  United States
Account Disabled
Default Re: Using Many Small Signal transistors for the output stage Update!!
one reason could be thost 0.4ohm "resistors": they are effectice inductors / transformers that send signals back and forth among those transistors. Not a good idea I would say.
Using Many Small Signal Transistors Paralleled in place of one output Transistor John Biles Solid State 33 21st August 2011 09:42 AM
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 07:51 PM
Substitute for Small signal transistors in crown 1400 csl bobcat Solid State 2 2nd August 2009 11:51 AM
Safe use of unknown small signal transistors mashaffer Parts 8 29th July 2008 12:35 AM
Page generated in 0.11103 seconds (79.97% PHP - 20.03% MySQL) with 11 queries
