Can I use-35-0-35 volt DC for Leach Amp?
Old 8th August 2005, 04:10 PM   #1
Wynand is offline Wynand  South Africa
Wynand's Avatar
Default Can I use-35-0-35 volt DC for Leach Amp?
The subject line saiz it all...if not, what is the minimum voltage rails required? ANY info will be appreciated.
Old 8th August 2005, 04:25 PM   #2
loek is offline loek  Netherlands
Default leach psu
My old Leach(1980) runs fine on 2x 40v DC...
Loek
Old 8th August 2005, 07:26 PM   #3
your peak output voltage will be about 28V.
this limits your power to about 50W into 8r, about 90W into 4r and about 130W into 2r. I have assumed a 300VA transformer driving both channels at the same time.
All these speakers can be of the severe rating (60degree phase angle) since the low voltage rails do not stress the output transistors.
Since it performs so well into 2r you could consider bridging if you need more power;- 180W into 8r at 60degree phase angle. The 300VA and two PCBs now form a single channel amp. It would be cheaper to buy a higher voltage transformer for more power.
regards Andrew T.
Old 8th August 2005, 07:57 PM   #4
BobEllis is offline BobEllis  United States
BobEllis's Avatar
Leach version 4.5 needs in excess of 40 volts to perform at its best - that is the reference voltage for the input stage cascode. Earlier versions did not use these zeners, and may perform well on lower rails. IIRC, Dr. Leach recommends >45V minimum.
Old 9th August 2005, 08:56 AM   #5
djk is offline djk
djk's Avatar
Easy to change the zener, or run a high voltage tier for the front end.
Old 9th August 2005, 11:31 AM   #6
skaara is offline skaara  Slovenia
Just change the zeners and it should work fine, i did that once for +-36V supply voltage and it worked well.
Old 9th August 2005, 02:55 PM   #7
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Now, what would be the slewrate of a bridged Leach amplifier ?
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 10th August 2005, 08:10 AM   #8
djk is offline djk
djk's Avatar
Slew rate is not important.
Since good audio performance is 2V/µS per peak volt of output, what we are specifing is rise time.
The rise time is substantially unchanged in bridge mode, as the slew rate doubles to go along with the doubling of the voltage swing.
Old 10th August 2005, 11:41 AM   #9
And if voltage of the output rails is halved, then bridged ?
Same output, double slewrate, halve the risetime ?
Old 11th August 2005, 08:24 AM   #10
djk is offline djk
djk's Avatar
The rise time shouldn't really change, and that's all that matters.
Can I use-35-0-35 volt DC for Leach Amp?Hide this!Advertise here!
My Leach Amp Clone (LEACH 150) panson_hk Solid State 32 22nd May 2014 12:25 PM
High Current Leach/leach super amp bowdown Solid State 41 2nd March 2011 03:15 PM
Switching 230 Volt Transformer to 120 Volt OMNIFEX Parts 10 6th April 2008 05:34 PM
Leach Superamp vs Leach 4.5 Samuel Jayaraj Solid State 4 26th October 2002 10:20 AM
Leach amp vs super Leach amp supernet Solid State 0 21st February 2002 11:16 PM
Copyright ©1999-2017 diyAudio
