Old 2nd August 2005, 08:49 PM   #1
jacquesl's Avatar
Default Need expert help on a project, ETI-488 100W
I want to know if it possible to bridge 4 or even more unit of this amp because I want to built a very strong amp, I can already get a 500VA 35-35 transformer for +- $102 just remember I life in South Africa it’s R613.00 there
The resone why I want to use this ETI-480 because it’s the only one I can make and understand well enough I already build 2 modules in other amp in my modified maranz model 1060, It’s all done with parts my friends give me and other stuff, so I where lucky there
Old 2nd August 2005, 08:53 PM   #2
jacquesl's Avatar
And in my papers it tell me how to bridge 2 units but I don’t understand that coz it sound like that dude also didn’t know what he’s talking about it’s making me confessed
Is where a way to put more output transistors on a unit
Old 3rd August 2005, 06:11 AM   #3
djk is offline djk
djk's Avatar
A 35-0-35 500VA transformer will drive 350W/8R for one (bridged) channel. The MJ15003/04 would be best, but the drivers will need to be changed to MJE15028/29 (or higher PN), and mounted upside down (because pin-out is reversed). Other changes will also be needed.
If driving 4R the outputs will need to be doubled (if only driving 8R with REAL GOOD heatsinks one pair will be OK), and a bigger transformer used.
A 30-0-30 700VA transformer will drive 250W/8R in stereo, about 350W/4R (limited duty cycle).
Old 7th August 2005, 02:22 PM   #4
jacquesl's Avatar
Can someone please give me all the problems this unit can give me and how to fix it, because I'm abut scared to power up the unit because the resisters "100 Ohms" you must put in place of the fuses is getting RED hot,
Newb looking for some expert advice for his first project (5.1 speakers) tim_programmer Multi-Way 3 19th July 2008 05:42 AM
My 1st Project - Need your expert help! Chooban Full Range 15 24th April 2008 11:10 PM
Project 100W MJ15003 MJ15004 Risto80 Solid State 7 1st July 2007 11:08 PM
Project 100W MJ15003 MJ15004 Risto80 Car Audio 2 26th June 2007 02:41 PM
ESP Project 3A - 60-100W Hi-Fi Amplifier Problem and need helps bugbite2k Solid State 18 31st December 2004 01:18 PM
Copyright ©1999-2013 diyAudio
