Old 31st July 2005, 06:42 PM   #11
Frank Berry's Avatar
"Will this bullsh%t about time delay ever stop?"
Probably not.
I have designed video DA's (distribution amplifiers) using Analog Devices AD-847JN chips.
I use inverse feedback in my design and they perform beautifully into the multi-MHz region.
Still .... Inverse feedback is not a cure-all. It works well when used to improve the performance of a well-designed amplifier.
The bottom line is this: If the amplifier sounds like h**l without inverse feedback, it will sound like h**l when you add feedback.
Get the design right and then use a little stage-by-stage feedback to make your design "shine".
Frank
Old 31st July 2005, 07:13 PM   #12
MikeB is offline MikeB  Germany
MikeB's Avatar
Hi !
My expierience is, the really problematic thing about feedback is to
adjust the correct feedbackcompensation, not only to keep the amp
from oscillating, to avoid all forms of overshooting and ringing.
(Internal ringing, not visible at output)
But, 1us delay to rise to max slew is incredibly slow !
A very good amp is completely finished with slewing after 1us.
I remember ~50ns for this delay in sims, but have to recheck.
Anytime i "improved" feedbackbehaviour, the amp sounded better...
I have not found out yet what kind of distortions are caused by
"improper" feedback, but seems to be related to reactive loads.
The less gain an amp has, the easier it is to get this proper behaviour.
Mike
Old 31st July 2005, 07:25 PM   #13
Jorge is offline Jorge  Brazil
Consider this:
Even in tube circuits, when electron flow at a relative inmensely slow speed through the tube semi vacuum from cathode to anode, still the time delays is of no concern for audio!
just because some japanse (chinese?) guys makes money of a 20$ chip amp that he sell for 2000$, doesn't mean that he rediculus theory about time delay and feedback is even remotely connect to any thrueth
PS
Q1: does a spice simulator actually take in to account the speed of electrical signals?...
Q2no? How can your simulatro then give any usefull info in this?
1 - There is no BS re time delay.
2 - I'm not aware of the guys selling snake oil. This posting is not related to them or they 'magic'.
3 - Not only does a Spice simulator takes in account the speed of electric signals, but in this very simple simulation it was taken in account.
It can give useful results because the amp has a pole at 80Hz (8MHz bandwidth and gain of 100k). This is the real signal delay.
Electron speed, etc has very little to do with feedback audio amps. The time to charge/discharge the compensating cap dominated the transient response.
Old 31st July 2005, 07:37 PM   #14
Originally posted by MBK
That's very interesting - I have never seen the actual time involved calculated or simulated. The interesting part is the error correction signal and the time scale. 1 usec is actually very slow - how can that be for a reasonably "fast" amplifier? The shape is horrendous too, I can imagine all sorts of bad things happening here...
My conceprual amp (posted in another thread) when submitted to the same signal has a delay of 100 nanoseconds (much wider bandwidth and more feedback gain).
And, believe one or not, no bad things are happening during the transient. After the inital rise, the feedback signal is just following the applied waveform (look at the second figure's slopes).
Old 31st July 2005, 07:42 PM   #15
tlf9999 is offline tlf9999  United States
Account Disabled
Originally posted by sam9
It's an obvious concern. I console my worries by the following train of thought.
Q1- What is the physical distance the feedback signal must travel?
A1- Well, in my board layouts it tends to be between 10mm and 50mm.
Q2- How fast does the feedback signal travel?
A2- I really don't know but it most certainly is some significant fraction of C.
if you go through the numbers, you will realize that you need the signal pass to be very very long (on the scale of thousands of miles) to be of a concern on audio signals.
Old 31st July 2005, 07:44 PM   #16
Account Disabled
to me, the real bottom line is will the amp with feedback sound more or less like h**l than the original amp does.
Old 31st July 2005, 07:56 PM   #17
PMA is offline PMA  Europe
PMA's Avatar
All of the music signal coming from CD player is BW limited at 22kHz, that means about 17us rise time (10%-90%). The only quicker signal apparent at the amp input is EMI/RFI interference or DAC converter residuals. All of them no greater than milivolts or ten milivolts. Contemporary amp should have rise time no longer than hundreds of nanoseconds, that means 100 times faster than the steepest audio signal.
P.S.: it is a good practice to make an amp fast and to reduce bandwidth by input RC filter, so do not speak about feedback delay in this case please ....
Old 31st July 2005, 08:05 PM   #18
PMA's Avatar
The "discoveries" shown here are well known to every engineer as a feedback basis, and should not be misinterpreted.
Anyway, nothing new. Search for articles about slew distortion and transient distortion from the early seventies.
Old 31st July 2005, 08:08 PM   #19
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Default Re: Input & feedback signals
Originally posted by Jorge
One can see there's a delay during the transition time (rise and fall) and it disapears when the signal is stable (flat top and bottom).
Congratulations, you have discovered phase shift in square waves after they pass through a system with a pole.
Old 31st July 2005, 08:08 PM   #20
PMA's Avatar
The error signal itself is not a problem unless the input stage is saturated, this causes slew distortion. The cure is BJT LTP emitter degeneration or JFET input stage. Or CFB amp.
Page generated in 0.12431 seconds (83.96% PHP - 16.04% MySQL) with 11 queries
