trouble with high power amp
Old 31st July 2005, 04:17 AM   #11
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
Originally posted by anatech
2. If your transistors were shot, they become expensive wire. You blow fuses and that is not happening.
Not all the time.
Pending on the amplifier you can indeed lose the output transistors, not blow fuses, and have the amplifier not go into protect mode.
OMNIFEX
Old 31st July 2005, 11:39 AM   #12
anatech is offline anatech  Canada
anatech's Avatar
In that case you would have both emitter resistors and base resistors open. I have seen that very occasionally. But if the rest was working you would still get full power until the rest blew.
It has to be supply.
-Chris
Old 31st July 2005, 04:17 PM   #13
bombardon73 is offline bombardon73  Netherlands
Guys, there's something else. The amp also goes into protection mode when there are NO speakers attached to it.
When the 1e red LED starts to blink and you turn it up a bit the amsp goes into protection mode. So there's no way I can led the 2e LED burn.
I don't know if this is common with these amps, but they use some kind of technologie that checks the in and out(speaker) signal. Maybe that has something to do with it.
here's a link that tell something about that.
http://www.bell-audio.de/PRODUCTS/PS...ower_amps.html
Old 31st July 2005, 05:20 PM   #14
OMNIFEX's Avatar
Dude, to be honest, you may need to contact bell-audio.
I remember an amplifier that would go into protect mode, and, stay there (You had to literally turn off and on to reset it) if it clipped too
hard.
With your amp offering half output, its quite possible the amp
is going into protect mode because its seeing an overload once
it clips.
Amp protection circuitry can be anything the manufacter wants.
I can't say I've ever seen two different brands of amplifiers react
the same when it comes to the protection circuitry.
And I'm talking Pro Amps here............
Home amps are a little more predictable.
OMNIFEX
trouble with high power ampHide this!Advertise here!
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
TubelabSE power supply trouble wicked1 Tubelab 26 14th December 2008 07:59 PM
GC Power Supply Trouble blackreplica Chip Amps 54 18th May 2004 03:07 PM
More GC Power Trouble rampage101 Chip Amps 1 8th April 2004 01:58 AM
