hafler 500 upgrades... - Page 2 - diyAudio
Old 30th July 2005, 01:25 PM   #11
K-amps is offline K-amps  United States
K-amps's Avatar
Originally posted by djk
[B
"Would it be any good to bypass with 1000uF, then 100uF or 47uF then 0.1uF? (I have many 1000uF's lying around) "
That would be OK, but the 0.1F needs to be bigger, more like 0.47F~1F. This may cause the amplifier to oscillate. If it does, try adding about 5 ohms in series with this cap.
[/B]
This was helpful info. Is this oscillation (with the 0.1uF) more an issue with the Hafler or would it be an issue with a 555?
thanks!
Old 30th July 2005, 04:17 PM   #12
still4given's Avatar
" I still don't understand where you are attaching the 47uf by-pass caps."
Kind of hard to figure out "I usually add four solder lugs with internal teeth on top of the existing lugs. "? There is only one place in the amplifier with four solder lugs. Look at the main filter caps.
Are you being sarcastic? Was my question not clear?
How does your telling me that you add four solder lugs on top of the existing lugs tell me where the leads for the new caps attach?
OK, mine is a P500, so maybe it looks different but I don't see any solder lugs on the filter caps.
Let me ask in a different way. Do you wire the 47uf caps in parallel with the filter caps?
Thanks, Terry
Old 30th July 2005, 10:08 PM   #13
K-amps's Avatar
Thanks, Terry
Yes Terry, if you did them in series, you total amplifier capacitance would be about 44uF...
Old 30th July 2005, 11:12 PM   #14
rgulate the PS t the frnt end alone will prob make a huge difference, it did for my dh-200..
cheers
george a
Old 31st July 2005, 02:23 AM   #15
fab is online now fab  Canada
fab's Avatar
cheers
I completely agree !
Old 31st July 2005, 08:01 AM   #16
djk is offline djk
djk's Avatar
"rgulate the PS t the frnt end alone will prob make a huge difference, it did for my dh-200..
cheers"
I agree, but it is quite a project for many.
http://www.audioxpress.com/bksprods/pcbs/nelsonpass.htm
ITEM # PCBP-10B Pass/Thagard A75 Power Amplifier
From Audio Amateur Issues 4/92 and 1/93. Pass/Thagard A75 2-channel power amplifier power supply board. 3-3/8 " x 5". 1 lb. $8.95
http://www.passdiy.com/pdf/a75p2.pdf
Old 31st July 2005, 11:47 AM   #17
K-amps's Avatar
cheers"
Djk,
Will the main board work with 90v rails or just use the OSU?
Old 31st July 2005, 02:35 PM   #18
fab's Avatar
cheers"
The PASS is quite a good circuit but may be too big to fit in some amp cases. The use of IC regulators is also a good compromise for performance/complexity ratio.
Old 22nd October 2005, 06:41 AM   #19
lopan is offline lopan  United States
Briefly looking at the schematics for a DH 500, I believe the removal of D11, D12, D13 and D14 would improve transient response at the expense of over voltage protection but it should make a significant imoprovement.
Also changing the bridge DB401 to soft recovery diodes might soften the amps sound. Not sure but no danger here.
DON'T remove the fan.
Additionally removing the output relay would definitely reduce output impeadance and therefore increase the damping characteristics. But you would need to build some protection in at the power supply and beware that this relay suorts the caps when powered down. Without the relay the caps will drain very slowly.
There is a 100 uf bypass on the board thogh this is electrolytic and therefore could be improved.
Finally the output speaker fuses should be bypassed not high end equipement would dare this in the signal path.
Changes should be made one at a time. So that problems can be more easily resolved.
Let me know what you think
Take care
APT Preamp and Amp Upgrades Jon_Dunlap Solid State 1 13th July 2015 06:36 AM
Upgrades for D1 sixty9 Pass Labs 13 2nd July 2012 09:18 AM
ESS AMT 4 Upgrades dubhouse Planars & Exotics 10 10th May 2009 07:25 PM
t-amp upgrades Code Class D 1 14th January 2006 04:12 PM
Copyright 1999-2017 diyAudio
