I have a blown channel on a Sumo Andromeda III
It uses IRFP240/IRFP9243 combo. The 9243's are no longer available and IR recommends the IRFP9240 as a replacement. I cant find any data sheets on the 9243 to compare. This is a fully balanced amplifier in which the output gnds. are not grounded to chassis. I have seperate bias & null adjustments for each side of balanced amplifier for one channel. I dont trust the settings on the good channel and looking for recomendations on bias. I believe the null is set 0 to ground on each side and not between + & - since this is fully balanced. |
#2 |
this is distortion null not dc null, dc is nullified by servo
http://www.datasheetarchive.com/semi...asheet=1003197 |
#3 |
#4 |
Thanks for the datasheets
Whats the chance of a schematic or bias/null settings for this amp? |
#5 | |
Several Sumo amps were designed by James Buongiorno. You could trying asking him about the settings: jamesbongiorno@ampzilla2000.com In any case his balanced amps were in fact bridged amps, so I don't know if it's accurate to call them balanced amps. And I think null & bias was carried out separately on each side of the bridge. There should be some information on the web, but I failed to find it just now. Carlos |
#6 | |
#7 |
The URL seems to be outdated, as it doesn't get us where it should.
Seems to be happening a lot with most of my circuit listing places. Carlos |
#8 |
Carlos, please open
http://home.kimo.com.tw/skychutw/Circuits/ then click on Andromeda II, it is here |
#9 | |
Did you try it? If you click on any of the blue names it gets you here: http://tw.home.yahoo.com/member/h/noreferrer.html |
#10 |
| Sumo andromeda II - Broken.. | Sponkii | Solid State | 47 | 18th August 2011 10:10 AM |
| Sumo Andromeda restoration | weinstro | Solid State | 0 | 11th April 2009 06:04 AM |
| Sumo Andromeda mods | ben12345 | Solid State | 1 | 18th February 2009 05:50 AM |
| Sumo Andromeda Class AB | rale0n | Solid State | 6 | 5th October 2008 10:49 AM |
| FS SUMO Andromeda for parts | woody | Swap Meet | 1 | 22nd April 2008 12:00 PM |
| Page generated in 0.16866 seconds (77.93% PHP - 22.07% MySQL) with 11 queries |
