If you capsule of vinyls it's broken, you can use this.For make tjis capsule I used a mic and cost pin
Cool |
#2 |
But, i am afraid that electret condenser microphone, the normal ones, the standard ones we can buy in electronic shops, the ones that are very cheap, will cannot reproduce all the audio spectrum.
Phono equalization will produce enormous bass and electrec condenser microphone limits of high frequency may be perceived, as the more common is to start to loose audio sensitivity around 12 Khz (the normal cartridges, as you have Senheiser special units very different) Tell us, your listening impressions with that clever adaptation. Congratulacciones hermano, hay que esto es la pura expression de la filosofia do haga usted mismo. Congratulations brother, because this is the perfect philosophic expression of diy. I loved your experience....give us more details, the way you fix the "needle" into the cartridge and more informations related the weigth you had to re-adjust, the sound produced too. ahahahah!...chiiiiii pirata hotmail.com.....aahahahahaha! very good mood man! regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine. |
#3 |
Hi!
The cost pin is paste to diaphragm of microphone with hard glue: Loctite. I use the PC for recording the sound of this capsule, the equalizer RIAA I do with “Adobe Audition”. Creo que los brasileños hablais algo de castellano si es así ¡saludos desde España!
Cool |
| "TECHNO"Amp building in progress-using "Iron Method" | zox2003 | Solid State | 23 | 30th March 2010 08:42 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| What makes Nichicon "muse"/"for audio" caps different ? | percy | Parts | 2 | 3rd October 2009 05:53 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.07091 seconds (71.99% PHP - 28.01% MySQL) with 11 queries |
