Which commercial amps still ..... - Page 2 - diyAudio
Old 29th July 2005, 11:12 PM   #11
anatech is offline anatech  Canada
anatech's Avatar
I love the Symphony.
I have tubes, and sand.
PSB's make me happy now.
Question, why on earth do you want a pro amp??? and why Mosfet for heaven's sake??? (I sold one of the last new Nikko Alpha III's in Canada - long history with mosfets).
There are many excellent consumer amps. Some of them are bipolar. Some of them tube. I own all types and they each have their strong points. Mosfet are my least favorite types.
Just asking 'cause I don't know if you have had the opportunity to actually listen to a number of amps. Don't listen to anyone until you have heard for yourself what is deemed to be good.
-Chris
Old 29th July 2005, 11:22 PM   #12
steenoe is offline steenoe  Denmark
steenoe's Avatar
I think Denon is running Lateral MosFet output's!
Steen
Old 29th July 2005, 11:44 PM   #13
Madmike2's Avatar
I was under the impression that MOSfet was still the best sound in solid state ... have i been misinformed ? almost all the hi end non tube gear and hybrid gear is MOSfet isnt it ?
I wont buy Denon , ever.
I had tubes before, just crap speakers to play them with.
Persistence is better then intelligence. Unless persistence kills you.
Old 30th July 2005, 09:02 AM   #14
pinkmouse's Avatar
If you can get it over there, Arcam kit uses mosfets, and doesn't sound half bad either.
I'm with Chris though, don't buy anything over, say, $100 until you have auditioned it.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 30th July 2005, 02:23 PM   #15
anatech's Avatar
Hi Madmike2,
You have been mis-informed. There are many great amps built with all known output devices. Circuit design and output stages run in cycles and are subject to "fads". The designer must be able to build a product that sells. We are getting over the mosfet fad - again.
I am convinced that if someone built germanium outputs that were semi-reliable, we would see a craze over this "forgotten" technology.
Basically, each output device does some things well and other things not so well. Mosfets have a gate charge problem, bipolars have an exponential transfer function and tubes + transformers have another set of troubles. I own some really good bipolar amps, and some really good tube amps. I wish I could roll them into one amp. The mosfet amps I have owned or worked on do not excite me, but that's me.
So ignore the technology of the amplifier and just listen to it. Do not listen to the sales guy, especially not the magasines. You really need to hear the amp in your home over some days to evaluate it. You also need to look at the support history of the company. Can you get parts and how well are the repairs done? Get a schematic or service manual. If the manufacturer won't release the information, walk.
-Chris
Old 30th July 2005, 02:33 PM   #16
Madmike2's Avatar
Oh and it starts again for me (indecision) I dont have the pull or capability to audition amps from the boys in T.O . I can go rent amps but they are all going to be Pro gear regardless of where i go.
I started this with a firm belief set which was slowly destroyed. The only thing that stayed constant so far was SS amps MOSfet. Now you single handidly have destroyed that as well (since no one is refuting him)
I am a blank paper again now. Must stay away from Future shop or ill be buying the pretty Panasonic Digital amp for only 299 !!! The glaze will leave my eyes once i return home.
On a side note, i did rent the ART audio SLA 2 and it was trash. 2 x 200 watts and my 27 year old pioneer smoked it. George Forman style.
Old 30th July 2005, 02:45 PM   #17
anatech's Avatar
Okay Madmike2,
Just audition these in the store to weed out the terrible ones. Be honest with the salespeople about your opinions. Don't forget that most of these people haven't a clue these days. Your opinion is just as valid as theirs.
Listen to the better speakers with these. You don't care about the bass yet. Listen for clarity in the mids and highs. Also listen for the (many terms around) feel or rhythm of the music, or how musical it sounds. Use music you know (bring your CD's that are natural sounding). Anything that fails this test will drive you nuts. Listen in mono, or one channel only if you can. You need to hear the music, not the mix or effects.
The bass depends a great deal on the speaker and room. You may be able to tell if the bass is sloppy or uncontrolled after a while, but this can be difficult in different stores.
Try listening at home first, with your wife or girfriend. It's amazing how well they can hear even if they don't know the terms. If they don't like something, there is something to it. Young children are good for this too.
-Chris
Old 30th July 2005, 05:37 PM   #18
Pass Labs still up there for sound quality going all the way back to *gasp* the 90's !
Now I've just got to ask what does sound quality from the 90's sound like? Yes, thats a rediclous statement at best. My system back in the late 90's consisted of a KSA-80B, KBL line stage, PH-3 phono stage and so onand so forth. I still own the same Dynaudios I had back in the late 90's with that equipment and they're still better sounding than most of the speakers available in the same price range today. Many friends agree with that completely. Today I use those same speakers with either a DIY pair of Pass Labs Aleph 2's or my DIY KSA-50 mk-2's either of them driven by the same DIY Grounded Grid Line stage. Either configuration sounds fantastic to say the least. Both amps sound completely different, both are fairly old designs but both are amazing pieces of quipment that I built to much higher standards than either factory does. Thats what DIY allows you to do.
Todays Pass Labs equipment is far different than what they were building back in the 90's and doesn't even vaguely resemble the sound of the first product line (Aleph Series). they are even much better but the Aleph series is still in my experience a great amplifier who's sound characteristics don't dictate that it was built in the 90's.
So what does 90's sound sound like? I couldn't tell you but perhaps you could enlighten us......
Thanks,
Mark
Old 30th July 2005, 06:18 PM   #19
pinkmouse's Avatar
The Spice Girls?
Old 30th July 2005, 07:31 PM   #20
Madmike2's Avatar
Hmmm i will quell my need to try and be funny. Its does not translate well on line. I was not dissin' any products dude just trying to add a little levity to an otherwise mundane comment i made. humour off.
Commercial or DIY amps Dr_EM Solid State 48 20th May 2008 06:12 AM
Any new commercial Class-D amps available? iwamusr Class D 0 18th December 2007 07:37 PM
Industrial vs Commercial amps and OPT's homemade Tubes / Valves 10 28th September 2007 04:18 AM
Expensive Commercial Amps Bryan Tubes / Valves 27 21st September 2005 09:29 AM
Other commercial chip amps bilbobaggins Chip Amps 6 18th March 2004 07:57 PM
Copyright 1999-2017 diyAudio
