Old 15th October 2005, 05:01 PM   #601
jarkaa is offline jarkaa  Finland
And after etching...
The result wasn´t that good but these are prototypes only... maybe...
I have to go shopping on moday because I could not find suitable resistors from my stash
Jarno
Old 15th October 2005, 06:21 PM   #602
MikeB is offline MikeB  Germany
MikeB's Avatar
Hi Jarno !
I don't see any flaws in the etching, looks well done !
Obviously you have more than enough devices... Going to build a 5 channel ?
For resistors i use normal metalfilm 250mw resistors, except the
4.7/1.2/10 in outputstage, there i use 2watt version (also metalfilm). And the 0.22ohms are 5watts.
The trimpot is a normal Piher.
Happy drilling !
Mike
Old 15th October 2005, 06:42 PM   #603
Hello Mike
Drilling is tomorrows business... Now it´s time for a couple of biers.
You should have a few too!
This is way OT but I am beginning to be worried about myself. I got few friends over on the other room and I am here browsing throuhgt the forums
I´ll be back after drilling and assembly is done
Jarno
Old 15th October 2005, 10:52 PM   #604
MikeB's Avatar
Hello !
I started to collect important informations about symasym into a webpage...
http://www.lf-pro.net/mbittner/Sym5_.../symasym5.html
Suggestions/critics welcome !
Mike
Old 16th October 2005, 01:38 AM   #605
anatech is offline anatech  Canada
anatech's Avatar
Hi Mike,
Your site is very clear, and loads fast. I like it.
-Chris
Old 16th October 2005, 03:37 AM   #606
mod_evil's Avatar
Send a message via MSN to mod_evil
Hi, mr MikeB.
Can I use this amplifier with 1ohm? How I can use it on 1ohm? Addiding more pair of output transistors?
Thanks a lot.
Brazilian Tube Amp Builder.
Old 16th October 2005, 07:43 AM   #607
PMA is offline PMA  Europe
PMA's Avatar
Mike,
thanks for creating the webpage. This will greatly help diyers interested in the project.
Pavel
Old 16th October 2005, 09:38 AM   #608
sajti is offline sajti  Hungary
Originally posted by mod_evil
Hi, mr MikeB.
Thanks a lot.
More output devices are not enough. To drive 1ohm load, You need to use predrivers between the VAS, and the MJEs.
sajti
Old 16th October 2005, 10:06 AM   #609
MikeB's Avatar
Hi mod_evil !
Symasym was not designed to deliver THAT much current, it does easily drive a 4ohm speaker, but not 1 ohm...
To do that, it would need a complete redesign. The VAS does not supply enough current, and changing it to triple darlington like sajti suggested will make it oscillate without further modification.
One possibility would be changing the outputstage to mosfets, and put enough of them in paralell.
Mike
Old 16th October 2005, 10:23 AM   #610
PMA's Avatar
Do not forget their high input capacitance.
Page generated in 0.10241 seconds (66.63% PHP - 33.37% MySQL) with 11 queries
