Old 23rd September 2011, 01:51 PM   #3871
The DCB1 is a DC coupled source.
You should not bypass the only DC blocking capacitor.
If you have the experience to recognise the pitfalls of converting an AC coupled system into a mixed AC and DC coupled system then go ahead and make that informed decision.
The B1 is an AC coupled source and with that you can safely bypass the DC blocking cap in the Symasym.
regards Andrew T.
Old 23rd September 2011, 07:30 PM   #3872
sakis is offline sakis  Greece
sakis's Avatar
Originally Posted by AndrewT View Post
probably lot's of people have tried.
Take any AC coupled Power Amplifier and connect it to an AC coupled output stage of the source equipment.
You now have doubled the DC blocking capability of the Source to Amplifier connection.
There is absolutely no benefit in double blocking the connection.
The solution is easy.
Go into both pieces of equipment and determine which blocking capacitor is doing most harm to the resulting sound quality. Short out that "not so good" blocking capacitor.
That solution is quite different from "Symasym without coupling caps".
Andrew is right (as usual) this is a very nice idea and often can be a huge improvment where ever is possible to do so .
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 23rd September 2011, 07:44 PM   #3873
Originally Posted by sakis View Post
Andrew is right (as usual) this is a very nice idea and often can be a huge improvement where ever is possible to do so .
and why I have been advocating dual inputs to Power amps and dual outputs from Sources.
Going back to Jens' Leach clone where he had installed 3pin input (0.1" sil) for the PCB.
The 3 pins offered AC coupled, or "test position", or DC blocker bypass, by just moving a 0.1" shorting plug. Takes near zero PCB space and near zero cost, for great flexibility in operation.
regards Andrew T.
Old 24th September 2011, 02:44 AM   #3874
Porfido is offline Porfido  Italy
My case!
Thanks, Andrew!
Old 5th February 2012, 02:02 AM   #3875
zsgh119 is offline zsgh119  China
x2-Symasym5-3 AMP
File Type: jpg 12012900242623d5b4b3c9b4b4_jpg_thumb.jpg (392.9 KB, 636 views)
Old 25th March 2012, 01:00 PM   #3876
Default symasym5.3
got this from M.Bittner site. same version with last thread why so many to92?
regards,
joel
Old 1st April 2012, 09:13 PM   #3877
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
regards,
joel
IŽd say nine,just as it should be....
Old 2nd April 2012, 04:39 AM   #3878
Default my mistake..
may be my eyes are just tired
regards,
joel
Old 2nd April 2012, 08:39 AM   #3879
44250's Avatar
Talking he he :)
regards,
joel
It could be an optical illusion,the way that they are spreaded on a pcb. I thougt the same thing before i counted them one by one. I have done SymAsym 5.3 and first thing i have noticed that is different on your pcb than on my is two diodes between E and C of output transistors. MURS120 exists on your pcb and on my they are not provided. It works anyway!
Old 13th April 2012, 08:52 PM   #3880
farhun is offline farhun  United States
regards,
joel
I couldn't locate where that pcb is from. Can someone direct me to the site where the pcb above sold? Thanks.
Page generated in 0.10646 seconds (65.44% PHP - 34.56% MySQL) with 11 queries
