DIY Enlosure for Power Amp
Old 17th July 2005, 07:24 AM   #11
r!sc! is offline r!sc!  Serbia
Account Disabled
Originally posted by pooge
Are you sure those are adequate for a power amplifier???
They are not small. Dimensions is 200mm x 75mm x 55 mm. I will use them for Medium Power Amp (Elektor project).
Boban
Old 17th July 2005, 07:26 AM   #12
Account Disabled
Originally posted by steenoe
Depending on what they are meant for. For inspiration, here is two specimens I just finished today. The smaller one would be nice for a small ClassA amp or a hefty classA/B amp. The bigger fellow, well go figure.... If you wonder how the finish is made on alu-plates, have a look at this:
http://www.diyaudio.com/forums/showt...195#post474195
Steen
Steen, they look realy good
Boban
DIY Enlosure for Power AmpHide this!Advertise here!
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
results of enlosure shape research Austin Multi-Way 19 26th July 2002 08:16 AM
Which stuffing material to increase "perceived" enlosure size? Two Moons Multi-Way 4 6th January 2002 04:27 PM
