Old 16th September 2002, 11:52 AM   #1
Exclamation How to convert Unbalance -> Balance Input ?
Hi.
I've bought this amp a while ago, it's rated at 185Wrms/Side. I'm hoping to convert the unbalance input to a balance one but not sure of the correct configuration.
Your help is must appreciated.
Here's the shematic.
Old 16th September 2002, 12:40 PM   #2
Mambo is offline Mambo  Italy
Try this, i took it from the service manual of an Aleph amp.
Old 16th September 2002, 01:24 PM   #3
I've just tried this in simulation, it works fine but I'm not sure about the values of the extra resistors; can someone help me?
Mambo, haven't you forgotten to place a cap in series with R39??
best regards,
HB.
Old 16th September 2002, 01:46 PM   #4
The resistor values are high enough so to not put excessive load in the preceding stage, unless you are using a pre "really" capable of driving lower loads. With the values shown the input impedance is a bout 10K unbal and 25K when balanced.
Putting a cap in series with R39 greatly increases the quantity of DC at the output.
Mambo
Old 16th September 2002, 02:49 PM   #5
Thanks guys.
Mambo, the circuit works fine in EWB.
Thanks again.
Old 16th September 2002, 04:39 PM   #6
PMA is offline PMA  Europe
PMA's Avatar
You can try following one .. (R = 10k, Rs = 100 Ohm, A1 = A2 = OPA134)
Old 16th September 2002, 04:55 PM   #7
mrfeedback's Avatar
Default Passive Soloution
Minh,
A car audio DC isolation transformer box works fine.
You may need to load down the secondary to avoid peaking response, and you can add a reversing switch to provide polarity reversal.
Car audio shops, St Lucia Electronics or WesComponents are a source.
$15-$30 for stereo.
I use this on my workbench and it works great - nobody has complained about the sound I'm getting.
Eric.
Old 16th September 2002, 06:08 PM   #8
traderbam's Avatar
Default a matter of balance
Hugo's schematic may work ok but bear in mind that the connection between -'ve input and the feedback node will tend to make the amp gain dependent on input impedance. I would think this would be undesireable.
PMA's approach looks better to me (although it adds more circuitry). Although using 2 op-amps is unecessary if you use a single op-amp in adder configuration: plus signal into the +'ve input with an R to gnd. Neg signal to -'ve input through a series R and and R from 've input to output.
Of course you could also configure the amp itself as an adder but the need for stabilizing components and the low resistance from -'ve input to gnd may not be desireable for the inputs (depends whats driving the inputs).
Another way is simply to use only one half of the unbalanced input signal. Ignore the other half. This will work fine although the noise cancelling benefits of the balance line will be lost, but sometimes this is an acceptable compromise.
Good luck,
BAM
Old 16th September 2002, 07:25 PM   #9
djdan is offline djdan  Romania
Minh
Please , give us more information about this amplifier.
It is a "pro" or "hi-fi" amplifier ?
How it work on 4 ohms ?
How it is sound quality ?
Regards ,
Old 16th September 2002, 08:08 PM   #10
PMA's Avatar
BAM,
the reason of using 2 opamps (in general) is to maintain the same output impedance of the + and - output. The circuit should not be influenced by following circuitry.
Pavel
About the NAD s200 bal-input not balance? Wizard Solid State 0 12th May 2007 07:11 PM
very low noise balance to unbalance converter YUTK Solid State 10 12th November 2005 05:00 PM
convert Quad44 radio input to CD input jives11 Solid State 11 5th March 2005 02:33 PM
Balance Input For Aleph-X thomasfw Pass Labs 2 26th January 2005 04:35 PM
Converting balance to unbalanced input diyman Solid State 4 7th March 2004 09:16 PM
Page generated in 0.11067 seconds (78.06% PHP - 21.94% MySQL) with 11 queries
