Old 4th July 2005, 06:37 PM   #1
Andypairo's Avatar
Default MOX + super regulator wiring
Hello,
after a long time I finally managed to bring my active x-over project closer to conclusion.
It is based on the MOX boards from the first group buy and it uses a pair of ALW boards for the Jung super regulator.
The supply is taken from a dual 15V 100VA toroid, each secondary is rectified with Fairchild Stealth diodes, smoothed with 4700 uF / 40V Siemens Sikorel caps and feeds a super-regulator.
Being the secondaries dual the supplies are floating and need to be referenced to each other.
Looking at ALW's guide I see that the recommended wiring for multiple loads is like this:
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 4th July 2005, 06:42 PM   #2
Andypairo's Avatar
... however this would mean that I should join the V+ and V- "ground" wires at each of the MOX boards and this maybe is not the best solution so far.... did anyone experience a similar problem?
With the gainclone regulated supply it is suggested to join the "gnd" wires close to the amps and to go from there to the boards... if this better?
Cheers
Andrea
Old 4th July 2005, 08:30 PM   #3
moamps is offline moamps  Croatia
Hi Andrea,
I used the wiring diagram shown in the picture below (standard regs instead of Jungs) a couple of times with good results.
Milan
Old 5th July 2005, 07:29 AM   #4
Andypairo's Avatar
thanks Milan,
I was also thinking about using a similar layout, but I was wondering if there is a "optimal" solution for Jung-like regulators.
Cheers
Andrea
Old 5th July 2005, 08:33 AM   #5
Bricolo is offline Bricolo  France
Bricolo's Avatar
optimal and the easiest to implement would be 1 reg per board
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 5th July 2005, 12:05 PM   #6
Andypairo's Avatar
Probably.... but that would mean another trafo and 2 other regulators (not that I don't I have the PCBs tough ).. with this level of complication I'd rather swap to batteries!
Cheers
Andrea
Super Regulator TheDriver Parts 2 21st July 2008 10:54 AM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
AD797 and Super Regulator Onvinyl Solid State 11 5th September 2007 05:08 PM
Super Regulator for DAC rockytro Digital Source 11 19th May 2006 07:31 PM
wiring Super Leach amp supernet Solid State 0 25th April 2002 05:08 PM
Page generated in 0.11342 seconds (66.90% PHP - 33.10% MySQL) with 11 queries
