#41 |
The JFETs are avilable for this:
#42 |
Account Disabled
Hi Nuvistor,
In practice the Ccomp could probably be reduced by 5 times giving a 10V/us slew rate FOR THE FIRST STAGE. This would be comparable with that of the chip. Zinsula, I'm sure the 2SK170 would be fine at 2mA (your comparison compares a 2SK369 at 3mA with the 2SK170 at 1mA) once Fletcher Munson and resistor noise is added. Still an order of magnitude below surface noise. Cheers, Greg |
#43 |
Hi ampguru -
I've done some LTspice simulation of your discrete + opamp circuit with 2sk369 and NE5534 models, acknowledgement to Uwe Beis for the NE5534. I tried flat gains of 5 and 50, Rf=1k, corresponding to RIAA MM and MC gain beyond 50kHz. With your compensation values I had no success with stable feedback at gains of 5 or 50. With Miller-integrator compensation of 20pF around the op amp with 5534 Cc=22pF I had success at 50 but not at 5. Avol is 130dB at 20Hz, 77dB at 20kHz, 33dB at 2.4MHz with phase margin of 45°. Perhaps some combination of input lag and Miller compensation could work at 5. The 2sk369 drain capacitance affects stability, I cascoded with 2N4392, without cascoding 45° pm is at 50dB, 300kHz. All of this reinforces my opinion that amplifiers with 3 gain stages are difficult to compensate simply at low closed-loop gains. |
#44 |
FYI, I just had a reply to an inquiry about 2SK146's:
"thank you for your enquiry via www.mark5.com. We are pleased to quote:- 6 min x 2SK146 at £11.37 each Delivery from Australia by Air Parcel Post at £15.44 10 days approx" Expensive, but maybe ok if a group of folk get together to purchase? |
#45 |
PeterMoreton,
Have you created the pcb for the Walter G. Jung phono pre ? |
#46 |
if you follow the link to my web page below, here is an article on RIAA preamps and a spread sheet to calculate the equalization network using the Lipshitz equations.
It is fun to build using discrete components, but value for money and performance probably favors an op-amp approach. Note that in the Baxandall circuit I discuss, you should use a buffer after the 2dary post filter - something AndrewT raised and that I will attend to when I write part 2. Right now though I am up to my eyeballs in my next power amp. ;-) RIAA Phono Equalizer, phono amplifier | hifisonix.com |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| serman |
| need a good low parts phono tube preamp schematic.... | Rockmonton | Tubes / Valves | 48 | 23rd December 2010 03:16 PM |
| Tube Phono Preamp PCB Ebay? are these any good | fortytwo | Tubes / Valves | 12 | 7th July 2009 02:47 AM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 10:51 PM |
| Audio Note Preamp Circuit a good guess... | ThorstenL | Tubes / Valves | 4 | 7th June 2007 12:09 AM |
| simple phono preamp circuit needed | needtubes | Tubes / Valves | 4 | 3rd July 2004 09:27 PM |
| Page generated in 0.10738 seconds (76.02% PHP - 23.98% MySQL) with 11 queries |
