#11 |
diyAudio Moderator Emeritus
Hey Mike!..
Yep..Gary Pimm has those as parafeed caps for his output tranformers. (The page I linked to was Gary Pimm's) Mine is still in this phase.. http://basenjes.de/tubes/gphono.htm well slightly further.... Mine will be without tranformers for starters by the way.. Regards, Bas |
#12 |
Thanks everyone; lots of good advice here. I'm going to build a simple opamp phono stage and see how this sounds. It may be good enough, using the latest and greatest opamps.
#13 |
Account Disabled
Hi Peter,
Simple's always a good place to start. The LM833 cct below as lifted from the link provided is close. only with the newer single op amps like LT1028, etc... A couple of improvements though , if you're doing a board. A series R should be added between the RIAA network and the output feedback point. This can serve two finctions - low Z loading limiter (as the RIAA > 0 at hf) ans cutting lathe 50KHz zero provision. When selecting the actual component values (recomment Andy C's website) or scaling the values shown, consider increasing the LF time constant considerably by increasing the 200K -> 300K for a fuller low bass consistent with a lack of 20Hz break in ther recording eq. jcx, The LT1028 has input stage bias cancellation so DC bias currents through the cartridge are likely acadaemic? Also the high Z source impedance source impedance you speak of , that would more suit a FET op amp, is dubious as the typical MM cartridge is usually characterised as , IK in series with 600mH and most audible nois according to Fletcher Munson is in the 500-3KHz range where source impedance is typ 2K-7Kohm. Also the RIAA eq at hf tends to further supress hf contribution. I vaguely recall NS doing an octave by octave analysis. But I have to agree with your - "..... if you are adventurous I would put 2 op amps with V gain inside the RIAA feedback loop (I would probably use a high speed current feedback dsl driver as the output op amp - and remember; composite amp frequency compensation is fun)" I would suggest a discrete FET diff'l pair followed by a high speed high drive op amp in one loop (all as the op amp pictured) with tailoring of the diff'l pair back to unity at hf for stability. Simple and effective AND fun! Cheers, Greg |
#14 |
check out the lt1028 i_noise spec, 1 pA/sqrt(hz) * 2-7 KOhms is 2-7 nV/sqrt(hz) right in your peak sensitivity region, the ad743 2.5-3 nV/sqrt(hz) V_noise is a bargan, clearly beating the lt1028 with mm cart
low freq 1/f noise could be a problem with other fet input op amps with the riaa Lf boost largely canceling the A weighting noise Lf roll off - the ad743 keeps the 1/f Vnoise corner lower than any other fet input op amp I know of |
#16 |
Just came across a schematic using two opamps sandwiching a passive filter (attached below). Walter Jung describes the technique in his paper "Topology Considerations for RIAA Phono Preamplifiers" which you can download from his website.
At the moment, this passive filter design is favorite, any comments from the experts? [ before I waste more time... :-) ] |
#17 |
#18 |
I don't have any favored theory whether active or passsive will sound better. andy_c's paper is impressive and there is a certain elegance into wrapping the whole thing neatly around a asingle opamp. However, being that I'm grey-mattert-limited, I find the passive approach easier to comprehend as it lets me think about just one thing at a time.
#19 |
Peter:
I've been happy using an Analog Devices AD743 driving National Semiconductor LM6321 unity gain buffer (NLA from National Greg's suggestion about using some JFETs followed by a high drive op amp sounds intriguing, too. Oddly enough, I've got a bunch of the old Toshiba low noise high gain JFETs paired in a can (2SK146?) that I should stick in front of an AD811 or something to see what happens. I've seen this approach in a number of Japanese receivers and integrated amps from the 1980's and early 1990's but usually with nice JFETS feeding some crappy op amp. Thanks for the flashback/reminder, Greg ... mlloyd1 |
#20 |
Attached is the Phono schematic that I'm settled upon (drawn in my PCB package) The design is an implementation of something I found in the TI/Burr-Brown OPA606 datasheet, and this itself draws upon ideas by Walter G. Jung (see : http://home.comcast.net/~walt-jung/w...7s-20PDFs.html)
Comments on the schematic most welcome (I'm a digital guy, so go easy on me!) I'll post the PCB overlay later. (If it's worthwhile!) |
| need a good low parts phono tube preamp schematic.... | Rockmonton | Tubes / Valves | 48 | 23rd December 2010 03:16 PM |
| Tube Phono Preamp PCB Ebay? are these any good | fortytwo | Tubes / Valves | 12 | 7th July 2009 02:47 AM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 10:51 PM |
| Audio Note Preamp Circuit a good guess... | ThorstenL | Tubes / Valves | 4 | 7th June 2007 12:09 AM |
| simple phono preamp circuit needed | needtubes | Tubes / Valves | 4 | 3rd July 2004 09:27 PM |
| Page generated in 0.15397 seconds (66.57% PHP - 33.43% MySQL) with 11 queries |
