I have designed another 0 dB Diamond Buffer Power Amp.
I use this Power Buffer with my SRPP+Cathode Follower TUBE E-80 pre-amp to make a pretty good sound Non-Global-Feedback Amp. With some changes from my ULTIMA-SDDB small Class-A power Amp and headphone amp , see my last thread at sziklai-darlington diamond buffer (SDDB) for power output stages , I desided to design this 0 dB Power Amp with double-Sziklai output stage. The INPUT stage is similar to LH0033.PDF fast buffer, but with cascode stage for JFET high voltage protect. So the output DC level can be adjustable by tunning the CCS current. About 40W with my tube pre-amp the output power can be achieved. ( not yet totally tested ) The bottleneck is the 2SK246BL's limited breakdown voltage only 50V, if use LS844 it will be better 60V. My Taiwan made E-80 tube amp.
EuLeit Audio Studio one of the best hi-end Amp design house in Taiwan http://www.euleitaudio.com |
#2 |
Account Disabled
Why not use a 2n7000 60V DMOS FET? Doubt it would be suitable for your current sources though with Idss=1mA for starters, but input. MOS in OK?
Greg |
#3 |
If Output power only is 40W, Why you use +/- 38V in output stage ?
The 2SK246 is limit 50V, Why don't to use Cascode by Q7 and Q12 ?
Sky Chu |
#4 |
hi, Greg,
I think MOS is not suitable for the input FET here. DMOS FETs are Enhancement type FETs, the Vgs will be positive voltage from gate to source. But JFETs are depletion type, the Vgs will be NEGTIVE voltage from gate to source. The source voltage of the Input JFET Q8 will higher than the input (gate) voltage, if we set it to be Vbe, then we can get pure DC output Buffer without using capacitors or DC-servo ckt. hi, skychu, I have a DZ T270 27-0-27 power transformer in my hand, so I use this to get a +/-38V DC. But I lower the voltage of the cascode Q7 (Q12) voltage to about 25V, and providing the Q14 (Q15) CCS sufficient voltage. The voltage of the output tage can be lower to +/-25V, only I have no other AC output voltage.
#5 | |
Sky Chu |
#6 |
You are right, it is just a normal common drain JFET with voltage reference.
#7 |
I think the 40W Power of this 0dB Diamond Buffer is enough, if we
make two Buffers as BTL with a high output Balanced Tube pre-Amps like ARC REF MKII. The maximum output could be triple or quadruple, about 150W!
#8 |
Account Disabled
What's the purpose of all this eclectic, complex, 'solution without a problem' electronic lego?
Have you heard of elegant simplicity? Or, indeed elegant sufficiency? Cheers, Greg |
#9 |
Hi Greg,
I think my amplifiers no matter with amplitude or not, basically are designed with simple structure , though look like complex circuit. Since my first My Ultima DB-01 Dual JFET+DB Head-Amp announced on Head-Fi at 10-18 2003, I began to design with the same structure using the same cascode JFET differential input stage, plus single- ended JFET+CCS voltage amplitude stage, I want to design a high voltage gain and large current output, so they can be pre-amp headphone amp as well as a power amp ---- my 150W ULTIMA-1 . And I love the diamond buffer and JFET's sound . But they are all Global-Feedback designed, since I bought my SRPP tube pre-amp, I think my power amp maybe can eliminate the differential input stage and voltage gain stage, just use a SIMPLE common drain JFET stage as input buffer plus a SIMPLE Power Diamond Buffer to drive not only the headphone but also the speakers. True, it came to be the same complex as my first amp, but I use only one pair SANKEN 2SC2922/2SA1216, to have large cuurent gain. And some circuit are for remote stand-by control optional. LEDs are for CCS and power on indicators. All BJTs are very cheap small signal except the driver and output stage, total cost is not very high. NGF 0dB Amp without the no-useful or no-benefit voltage ampltude stage maybe can achieve better noise, THD, phase-shift, ... I think it can sound more elegantly with the tube, but without output transformer.
#10 |
Hello Mtlin,
One of my Friend has built your headphone amp, i have also listened to the immaculate sound of that amp...its a great gift to DIYER'S ...... cheers, Kanwar
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
| four transistor emitter follower (diamond buffer) as power output stage? | capslock | Solid State | 99 | 14th September 2010 09:17 PM |
| Diamond Buffer - Super Buffer | peranders | Solid State | 34 | 16th May 2010 01:46 PM |
| what about diamond buffer MOSFET? | padamiecki | Solid State | 26 | 5th October 2005 03:55 PM |
| sziklai-darlington diamond buffer (SDDB) for power output stages | mtlin12 | Solid State | 5 | 1st April 2005 06:55 AM |
| Diamond buffer | peranders | Solid State | 45 | 15th November 2003 11:00 PM |
| Page generated in 0.14148 seconds (71.06% PHP - 28.94% MySQL) with 11 queries |
