Pls recommend a good class-A
Old 27th June 2005, 12:36 PM   #1
goldyrathore is offline goldyrathore  India
Cool Pls recommend a good class-A
Where can I find a good class-A (solid state) with a clean output of 25-30 Watts.
Thanks in advance,
Goldy
Audio enthusiast/hobbyist
Old 27th June 2005, 12:46 PM   #2
Stuart Easson is offline Stuart Easson  United Kingdom
Stuart Easson's Avatar
Pls recommend a good class-A Send a message via MSN to Stuart Easson Send a message via Yahoo to Stuart Easson
Default You want to build these?
Assuming you are talking about DIY, solidstate...
Zen v4
SOZ
miniAleph
Aleph 3 clone
Krell KSA clone
JLH
These are all really great amps, they have different strengths, weaknesses etc. You'll want to read peoples comments to find which could be the amp of choice for your needs.
There are probably others, if you perform a forum search for these you'll find many people who have built and are building them here.
HTH
Stuart
Old 28th June 2005, 04:27 AM   #3
amplifierguru is offline amplifierguru
Account Disabled
Hi goldy,
Here's one that's -
FET cascode input
comp MOSFET output with thermal comp.
DC coupled so no capacitor smearing
low cost low parts count
minimum Class A power consumption
can revert to class AB when you get your power bill!
A bit fiddly to set up
some DC drift.
Old 28th June 2005, 04:48 AM   #4
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
If thi is your first amplifier constriction project than either the Aleph Mini, Aleph 3, or the he Krell KSA-50 clone are really pretty easy. They are very different sound amps though so investigate before you build. The nice thing about the Krell, the Mini, or the 3 is that they do not really require any super accurate transistor selection to get excellent results as long as you get all your devices from the same lot code.
Investigate, build, listen, enjoy!
Mark
Old 6th July 2005, 09:10 PM   #5
chicco_36 is offline chicco_36  Macedonia
Default To amplifierguru
Your fet amp schematic is very interesting. Iím planning to build this amp, even did pcb layout in the Eagle wich wasnít hard at all. Can you give me (us) more info for successful results, like what else must be on the heatsinks except output transistors, and resistor values for safe class AB operation?
Also, wich diodes to use and right value of one resistor?
Thanks!
Old 7th July 2005, 12:53 PM   #6
AKSA is offline AKSA  Australia
I agree Chicco_36,
This simple design of Ampguru's elegantly solves many of the usual issues in audio amp design.
I think it's very clever, and it's simplicity and originality shows considerable depth of thought about the problem.......
Congratulations, Ampguru!
Now, how does it sound, and what are its strengths and weaknesses in Class AB?
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 7th July 2005, 05:28 PM   #7
jcx is offline jcx  United States
are we looking at the same schematic?
amplifierguru's "elegant" single ended circuit has an output Cap! -talk about "capacitor smearing" - has to be an electo for 8 Ohms load (typos happen, I expect 100 mF was meant) - electros are much worse in measurable distortion than the polypro or even polystyrene you could use as an input coupling cap with a fet
without input offset or other adjust for bias the amp will be very "fiddly" to avoid offset from fet idss distribution eating into output swing - show pots or tell where Rs need triming
Old 7th July 2005, 06:43 PM   #8
tschrama is offline tschrama  Netherlands
here's a dc coupled version... I think the original auteur didn't mean cap-coupled amp.. but to make use of the pinch-off voltage of a JFET.. now dc out is minimal...
Old 7th July 2005, 07:59 PM   #9
Geoff is offline Geoff  United Kingdom
I think you will find that the 8R+100nF is a Zobel network and that the speaker is in fact direct coupled to the top end of the 8R resistor.
An output electrolytic should not be used on a dual supply rail amp due to the lack of a dc polarising voltage (unless of course the output is deliberately set to give a dc voltage, but then you would lose some output voltage swing).
Old 8th July 2005, 01:10 AM   #10
there are a couple of schematic conventions to to avoid such confusion, simply extending gnd and output wires beyond the zobel would be a clue, attaching a R named Rload is definitive
nonpolar electrolytic output caps are preferred acording to Bateman, they have several times lower distortion than polar electros, even if the polars are biased
without output cap I would be suprised the cirucit would be safe without a regulated supply
Pls recommend a good class-AHide this!Advertise here!
Recommend a 2W, Class D mono for guitar jackinnj Instruments and Amps 13 24th December 2007 12:18 PM
recommend discrete Class D rellik Class D 11 3rd November 2005 01:27 AM
Can you recommend some good Mocacor tweeters? mr_push_pull Multi-Way 10 27th September 2004 10:15 AM
Copyright ©1999-2017 diyAudio
