Old 18th June 2005, 04:45 PM   #1
MaXiZ is offline MaXiZ  Italy
MaXiZ's Avatar
Send a message via ICQ to MaXiZ
Default 3-way crossover
I've build this...
http://sound.westhost.com/project09.htm
But i've a problem.
When i connect +/- on -v side i've +0.5..
I've replace ALL the TL082 with new one... some idea?
PSU IS:
LM7815/7915 and 2.000uF capacitor.
The "main" to LM come from my Power Amplifier PSU...
Old 19th June 2005, 12:47 AM   #2
djk is offline djk
djk's Avatar
Which specific opamp has the .5V?
Check the ground for the 100K input bias resistor.
The 3-way version of the crossover is hooked up wrong.
The correct order is:
Input buffer to HP and LP for your lower crossover point, LP to an all-pass filter set to your upper crossover point (may be omitted if more than 3 octaves apart). The HP from the lower crossover point the feeds the upper crossover HP and LP.
This may seem wrong as the HF goes through more opamps, but if you do it the ESP way the group delay will be way off.
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Help me with a crossover. raypalmer Multi-Way 4 5th April 2009 01:48 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Crossover help please :) Tenson Multi-Way 17 15th April 2006 09:34 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.07013 seconds (68.60% PHP - 31.40% MySQL) with 10 queries
